Postby mnickels » Fri Mar 26, 2010 10:07 pm
Misty emailed today and said Toby found the parts to get one mounting kit together so that is now on its way! My rear calipers were collected for refurb at Ward Engineering and the fronts went to Premier Autoparts to avoid a core part charge. The new ones are on their way already along with the belts, washer motor and track rod ends. I went and got the steel for the welder tomorrow too so it is still all systems go!!!
Postby Dan 6511 » Sat Mar 27, 2010 12:37 am
Great news Matt! Be sure to take lots of photos of the chassis being cut about and repaired. :D
Postby bozzzydmc » Sat Mar 27, 2010 6:08 pm
That's great matt ! Looking forward to seeing some more of your finished handywork !
Postby mnickels » Sat Mar 27, 2010 7:05 pm
Will try to get some pictures sorted for today later. The rot on the frame was all cut out and new steel put in its place, plates cut for the control arms and welded on. The material for the steering rack bushes arrived along with my battery isolation switch and fuel pump. The welder has to come back tomorrow to finish off the frame and my broken towing eye but that won't take long.
Postby Admin-bloke » Sat Mar 27, 2010 7:33 pm
I still have my battery isolator switch I bought about 4 years ago !
I will have to get that put on at some point :) more like 2012 at this rate :(
Postby mnickels » Sun Mar 28, 2010 9:10 pm
Here are some pics of the welding. Needs a few bits straightened out and cleaned up, but grinder broke so will have to wait.
Postby arranj » Sun Mar 28, 2010 9:55 pm
I have a question Matt. With all these bits welded on is it affecting the structural intergrity of the car as a whole?
Postby mnickels » Sun Mar 28, 2010 10:05 pm
arranj wrote:I have a question Matt. With all these bits welded on is it affecting the structural intergrity of the car as a whole?
I hope not. It is really only 2 plates on the back crossmember but you can see on either side. With the original bits rotting I would say it is stronger. If you are talking about the control arms I don't think it makes a whole lot of difference after Reading a DMC talk thread with each control arm simulated. Dan said when talking to him a few had it done though.
Postby mnickels » Tue Mar 30, 2010 1:27 pm
Finally got my TAB's removed using the burners in work. New front calipers, belts, washer motor, track rod ends, fuel pressure regulator and brake pads arrived today! Don't even think I got this many things to open at Christmas!
Frame is more or less ready to go to get coated. If I don't get it over today it'll go tomorrow with a week turnaround which will be slightly longer due to Easter hols. I have to take my condenser to get tidied up as well so busy times still.
Postby mnickels » Tue Mar 30, 2010 6:58 pm
Nightmare!!!
John Dore noticed my crossmember plate was put back on upside down. The box indentation is going upwards and not down.
Does it need to be there or if I had it cut out instead would it do? Problem is was looking frame away asap and welder wouldn't be available until weekend.
