Postby A Van » Fri Apr 02, 2010 1:12 pm
Keep going Matt, It'll be worth it!!
Postby mnickels » Fri Apr 02, 2010 1:50 pm
A Van wrote:Keep going Matt, It'll be worth it!!
Cheers Al. I know it will be. I have eurotec in mind and hopefully it will happen. If it doesn't it will be VW Bora again but might trailer the car across regardless.
Postby bozzzydmc » Fri Apr 02, 2010 1:58 pm
That being the case Matt, just bring the car with all the bits you have left to fit, we can all muck in and finish it off with you if you like buddy
Postby mnickels » Fri Apr 02, 2010 2:11 pm
bozzzydmc wrote:That being the case Matt, just bring the car with all the bits you have left to fit, we can all muck in and finish it off with you if you like buddy
I'll see what the cost is etc but hopefully it's not the case. Arran will need a 2 post lift installed in the car park at this rate lol
Postby RobvdVeer » Fri Apr 02, 2010 6:27 pm
The best suggestion for eurotec entertainment i've heard so far!
Postby mnickels » Sat Apr 03, 2010 3:28 pm
Deja vu.
The frame is now welded (the right way up). I'll clean up the welds and take photos later as it is pissing down. More wire brushing of the rear hub carriers and degreasing. Also wire brushed a bit more of the frame, this exposed 2 areas that required a small patch but now sorted as well.
Postby A Van » Sat Apr 03, 2010 3:35 pm
Back on track then!
Postby mnickels » Sat Apr 03, 2010 3:39 pm
A Van wrote:Back on track then!
Hopefully Al
Postby Dan 6511 » Sat Apr 03, 2010 10:06 pm
Excelent news Matt. When is it going for galvanizing?
Postby mnickels » Sat Apr 03, 2010 10:29 pm
Dan 6457 wrote:Excelent news Matt. When is it going for galvanizing?
Will drop it up on Tuesday all being well
