Postby ALEXAKOS » Tue Oct 28, 2014 10:00 am
Nope. The injectors are clipped into place and turnable;)
Hey what do you know? I managed to give YOU advice!!! Woohooooo!
Postby Admin-bloke » Tue Oct 28, 2014 10:06 am
Bolt the injectors to the fuel lines first. Use a spanner on the injector and a socket on the banjo bolt. Use a torque wrench and tighten to 12ft lb / 15nm.
Ideally user new washers, but If you need to reuse your original ones as an emergency, heat the old washer in a bunsen flame to a dark red the immediately drop it in oil or water. ..
Postby ALEXAKOS » Tue Oct 28, 2014 10:08 am
Aaaaaand that was the forensic version of it! Wow AB!
Postby RobvdVeer » Tue Oct 28, 2014 10:11 am
What size washers? Do I get them at a DIY store or a car parts specialist? How about the hollow bolts, do I need new ones? I've got 2 spares from when I did the VOD. I know they snap easily.
EDIT:
Thanks.
Thanks!
Thank you
and awesome, thanks.
Postby ALEXAKOS » Tue Oct 28, 2014 10:21 am
Order a complete set from Ed to be safe;) or you need a specialty store that sells high pressure hydraulics.
Postby Admin-bloke » Tue Oct 28, 2014 3:09 pm
I've never snapped one using a torque wrench..
Postby RobvdVeer » Tue Oct 28, 2014 3:15 pm
I dont want to waste an entire day and finish the job a week later just because i snap a stupid €1 bolt. And yes i have a little torque wrench (and a big one)
Postby ALEXAKOS » Tue Oct 28, 2014 3:22 pm
RobvdVeer wrote:I dont want to waste an entire day and finish the job a week later just because i snap a stupid €1 bolt. And yes i have a little torque wrench (and a big one)
The 1€ is the least of your troubles when snapping that bolt....
Think of all the bloody effort to extract it... Been there done that...
Postby RobvdVeer » Tue Oct 28, 2014 11:30 pm
Don't jinx it!
Postby RobvdVeer » Sat Dec 20, 2014 7:08 pm
Today I decided to turn over the car once more, it's been 3 months ago. After 2 primes from the pump she fired right up, no stalling or such nonsense. :dance:
Too cold to work on the injectors and fuel lines. No energy either. I guess it'll have to wait until 2015. :text-imnewhere:
