Postby mnickels » Thu Mar 25, 2010 12:17 pm
Following Al's reccomendation I contacted Dell'Orto directly about fuelling the beast. They recommended
Facet Red Top Competition Fuel Pump- pumps 35 gallons per hour!!!!
with
Filter King 85mm Pressure Regulator 1-7PSI
Unfortunately they are £75 and £55 respectively but after a quick ebay visit I got them both for £80.
Postby mnickels » Thu Mar 25, 2010 12:50 pm
Posted by Thomas, thought I'd share it
Postby mnickels » Thu Mar 25, 2010 6:30 pm
Massive shopathon today.
As previously mentioned I have ordered my fuel pump and pressure regulator. The DPNW sway bar mounting kit I require is out of stock so waiting word on that. Dan is going to the states and bringing me back wheel bearings, CV boot kits, an exterior door handle, TAB's and an auto trans cooler. From Premier Autoparts I have ordered front brake calipers, belts, washer motor and track rod ends. Off ebay I have also ordered front brake pads and a battery isolation switch.
I am going to try to replace the steering rack bushes myself and have ordered a 36mm X 500mm white acetal rod to get machined. I am waiting word back on headlights and my rear calipers are on their way to Ward engineering for refurb tomorrow. Martin is providing new front springs when they are available at the end of April.
Postby Admin-bloke » Thu Mar 25, 2010 6:35 pm
Might be worth getting a job lot of the steering rack bushes done if they work out to do the job!
Good luck with the project :)
Postby mnickels » Thu Mar 25, 2010 6:38 pm
Admin-bloke wrote:Might be worth getting a job lot of the steering rack bushes done if they work out to do the job!
If you look at Kennys on the DOI forum it looks the part. I will get whatever 500mm will produce I suppose. I would reckon that would be a fair few. It is only £6.67 for the material anyway so worth a try
Postby Admin-bloke » Thu Mar 25, 2010 6:41 pm
Let us all know how it goes, you might be the "steering rack bod!"
Postby A Van » Thu Mar 25, 2010 7:21 pm
Hehe...splendid work!
What did they say about linking them up?
Postby mnickels » Thu Mar 25, 2010 8:26 pm
He said fuel filter, fuel pump, regulator, t-pieces then carbs
Postby A Van » Thu Mar 25, 2010 9:01 pm
Righto
Thats that sorted then.
Postby mnickels » Thu Mar 25, 2010 9:09 pm
A Van wrote:Righto
Another thing off the list!!
