- Vin 11766 - To Do List...
Postby kckoopa » Tue Dec 13, 2011 11:51 am
So now I just want to fix a few little bits on my DeLorean, nothing too huge.
Soooo
1. I have one key for the door, and one key for the ignition. Can I get a set of locks to make it all use the same key? And if so is it a huge task or a fairly easy one.
2. There's a few cracks in the louvre appearing, probably from supporting the engine cover, I might have to watch the wheeler dealers episode again to get instructions on fibreglass repair but if anyone wants to chime in with advice on paint codes etc.
That's about it at the moment, Al has sorted 99% of the car, I'm just being picky!!
Reason: Topic moved to more suitable section ...regards Mike
- Ex Vin 11766 -
kckoopa
VIN #: 11766
Re: To Do List...
Postby A Van » Tue Dec 13, 2011 12:34 pm
I dont remember any cracks in the louvre, can you post a picture up
To Do List...
Postby kckoopa » Tue Dec 13, 2011 1:51 pm
A Van wrote:I dont remember any cracks in the louvre, can you post a picture up
will do when I get home, it's not major at all, might just be paint cracking!!
- Ex Vin 11766 -
kckoopa
VIN #: 11766
To Do List...
Postby A Van » Tue Dec 13, 2011 2:15 pm
I don't even remember that either!
Re: To Do List...
Postby RobvdVeer » Tue Dec 13, 2011 6:10 pm
with details like that, i don't think you'll ever run out of things to do :D
To Do List...
Postby kckoopa » Tue Dec 13, 2011 6:40 pm
Don't worry, it's only new owner syndrome!
- Ex Vin 11766 -
kckoopa
VIN #: 11766
Re: To Do List...
Postby tourettes tony » Tue Dec 13, 2011 6:41 pm
kckoopa wrote:So now I just want to fix a few little bits on my DeLorean, nothing too huge.
Soooo
my car has 2 keys and is normal it was only the later ones that had 1, bare in mind that ignition sets are hard to get and expensive TT
Re: To Do List...
Postby jerzybondov » Tue Dec 13, 2011 7:05 pm
+1.
Not worth the hassle and expense to go to one key. If this is the greatest of the issues you've got with the car then you're doing better than 99% of us here! :D
Re: To Do List...
Postby arranj » Tue Dec 13, 2011 7:07 pm
If you have the 1 key it means Dan can open your door, as can probably nearly everyone else! :lol: The true connoisseur uses 2 keys! ;)
Re: To Do List...
Postby bozzzydmc » Tue Dec 13, 2011 7:08 pm
... And I thought every DeLorean had the same key ;)
