VIN 3283 Restoration
Re: VIN 3283 Restoration
Postby delorean12uk » Tue Apr 19, 2016 7:12 am
certainly looks impressive what the brothers are doing, maybe give Chris N a job. :lol:
Postby jamesrguk » Tue Apr 19, 2016 9:55 pm
Looks great.
I'll genuinely be very interested to see how your paint job on the Fascias hold up.
Were you using rattle cans? If so the only issue I keep coming up against is the lack of flex in the lacquer coat, I get about 4years then suddenly the lacquer starts to crack.
I can actually achieve a very good looking finish from off the shelf cans but it's the lacquer which seems to cause me the problems.
I even wrote to Practical Classics magazine to see if they knew of a flexible lacquer available off the shelf, indeed they published the question in the magazine, but the consensus is that they're really aren't any available.
When I redo mine this summer I think I'll ditch the lacquer coat.
Postby mec » Wed Apr 20, 2016 12:56 am
you will struggle to get any real shine if you don't use lacquer James, it doesn't have to be flexible lacquer as all paint and lacquer have a certain amount of flex anyway, think how many cars you see with dents in and the paint doesn't crack, obviously it will of if goes to far but a little flex in the plastic shouldnt effect it, I can highly recommend this lacquer ...
http://www.ebay.co.uk/itm/PRO-XL-CLEAR- ... SwyQtVlUZk
mike
Postby jamesrguk » Wed Apr 20, 2016 9:51 pm
mec wrote:you will struggle to get any real shine if you don't use lacquer James, it doesn't have to be flexible lacquer as all paint and lacquer have a certain amount of flex anyway, think how many cars you see with dents in and the paint doesn't crack, obviously it will of if goes to far but a little flex in the plastic shouldnt effect it, I can highly recommend this lacquer ...
mike
Yes sorry I'm talking about paint/lacquer from a rattle can.
When painted by professionals I understand that a plasticiser is included in the mix to give flexibility in the paint/lacquer and you can't do this with a rattle can.
Mine was absolutely fine for a good few years when I first painted and lacquered it, but then a fatty at a wedding perched on the corner and a crack in the lacquer appeared, then I pushed the car into the garage hands on the bumper and more cracks.
I will probably redo it in the summer, but it will always be a temporary job from a rattle can, that said it's very cheap fix.
I'm waiting for new fibreglass front and rear fascia, potentially from Chris N which I will then have professionally painted. I don't want to pay for a professional paint job when my original Fascias are so poor.
Postby jerzybondov » Thu Apr 21, 2016 12:18 am
You not worried about slapping a load of weight onto the ends of your car with fiberglass fascias James? They're proper heavy!
Postby mec » Thu Apr 21, 2016 1:06 am
Yea I know you meant rattle cans James, We didn't use any plasticiser on mine when i had them painted at work in a oven so i don't see why rattle cans should crack any more than a "professional" paint job, the problem with using plasticiser is that it makes the paint lose its adhesive qualities so then you end up with paint peeling off like mine did before I had them done, that link I attached was lacquer in a rattle can, I have used quite a few different makes and this one in my opinion is best, the quality of the paint/laquer can vary which maybe why yours has cracked
mike
Postby delorean12uk » Thu Apr 21, 2016 8:10 am
jamesrguk wrote:I'm waiting for new fibreglass front and rear fascia, potentially from Chris N which I will then have professionally painted. I don't want to pay for a professional paint job when my original Fascias are so poor.J
James, I think the original front and rear fascia's would be better than fibre glass. As long as they are prepared properly. I know they warp but that's nothing for a heat gun to sort out. Mine had some severe warping in places and and I straightened them out okay. As long as plasticiser is used in the paint job they would be okay. They also have a lot more give and flexibility than fibre glass, fibre glass would crack a lot easier
Users browsing this forum: The Back Door [Bot] and 33 guests
