I replaced the fuel pump and lines after the last few posts. All ok i hope?
My top shock washers needed replacing. The original small spax bushes were a bit overworked too.
- 20170930_163556.jpg (1.43 MiB) Viewed 8718 times
The new rubbers are much bigger, and the top and bottom washers rather better for the job.
- 20171021_133617.jpg (1.15 MiB) Viewed 8718 times
Also fitted the spangly new, probably-not-very-good-but-we-definitely-prefer-it-NLA angle drive.
- 20171021_133631.jpg (1.12 MiB) Viewed 8718 times
I do not enjoy working on the front sudpension!! Plenty of red rubber girling grease on the rubber. I also painted the same over the rear rubbers at the top of the springs to stop a super irritating squeak.
Car seems fine... I wonder what will go wrong next?
thats the joy of these things!
New exhaust some time soon. There's a little blow on it now which isnt going to fix itself. I note the top bracket is slightly fractured, and the rubbers are all a bit tired, and the heat shield looks like tin foil...
bye bye money! I didn't like you anyway!!
