Postby arranj » Fri Nov 24, 2017 1:16 pm
That is one of 2 gaskets that go on the W shaped pipe:
Postby Domi » Fri Nov 24, 2017 7:03 pm
Good choice of picture to show how the gasket goes :mrgreen:
Postby gruffalo » Sat Nov 25, 2017 1:34 am
arranj wrote:That is one of 2 gaskets that go on the W shaped pipe:
Is that a dude on the right? :|
Postby A Van » Sat Nov 25, 2017 10:15 am
Did the Volvo one fit?
Postby gruffalo » Sun Nov 26, 2017 11:28 pm
What Volvo piece are you referring to? The answer is most likely no. The only parts I have used so far are some screws and the sensor in the thermostat housing.
Postby gruffalo » Sat Dec 02, 2017 10:45 pm
I’m installing a heater / air conditioner in my garage right now, and doing some home maintenance, but still some progress. The two hoses for the heater are replaced and the spark plugs installed. I’m waiting for some pieces to finish off the rest. In theory I could be ready to start the engine in a few days. So maybe this year?
Status
Postby gruffalo » Sat Dec 16, 2017 10:24 pm
What’s this for?
Postby gruffalo » Sat Dec 16, 2017 10:28 pm
A close up
Postby cis6409 » Mon Dec 18, 2017 3:51 pm
Number 2 in that pic with the black connector is the connection for the diagnostic port ..
Very handy for telling you rpm , dwell etc
One part comes from the main loom and the other side comes out of the bottom of the diagnostic port which is located behind and to the left of the spark distributor , it's mounted to the rear of the left hand side head
The other white plug pic on the close up I'm not 100% on but I think it's the connector for the hot start relay via the cold start valve ..
Postby gruffalo » Mon Dec 18, 2017 5:50 pm
Thanks! The white one can be seen here too
Users browsing this forum: No registered users and 20 guests
