vin 11789 unusual to have this missing?
Postby Spudmurphy » Thu Mar 22, 2018 8:50 pm
Hi.
I've been spending a little time over the months working on vin 11789. I've replaced most of the fuel lines, all the vac hoses, water pipes, rad, expansion tank, and "dry fitted" everything in the engine bay. ( By that I mean no copper washers on the injector pipes or jubilee clips) I've refitted the exhaust and am about ready to try firing her up. But realised that it is missing (another) something. this ... On facebook Alistair confirmed that it should be there.
So before I lash out on a new one from Arran - does anybody have one for sale?
it's a shame because there's not a lot to it engineering wise - but I don't have the gear to make one.
rear stay red line.jpg (96.9 KiB) Viewed 4781 times
Re: vin 11789 unusual to have this missing?
Postby gruffalo » Fri Mar 23, 2018 9:14 am
Slightly off topic, but after opening three engines lately with ruined cams, I would recommend verifying that the rockers actually do spray oil onto the cam, before you start a car that has been sitting for a long time. In my case about half of them were clogged.
Postby Spudmurphy » Fri Mar 23, 2018 9:29 am
I've been following your progress on this and was wondering the same?
Damn damn damn You've persuaded me !!! :-)
Postby gruffalo » Fri Mar 23, 2018 10:59 am
Well, I’m not super experienced in the PRV domain, so you should probably get a second opinion.
The initial idea with my project was to get the engine to run with only superficial overhaul, but this failed brilliantly. The extended sitting had caused multiple fatal injuries to the engine. Clogged oilways, block rot, rust on cam, valve stems and seats, and last but not least rust in the cylinders. But maybe I was just unlucky.
I shouldn’t generalize over my single experience, seek advice (and motivation...) from others. I realize this wasn’t a motivational post. :|
Postby Spudmurphy » Fri Mar 23, 2018 2:19 pm
There are always risks when buying a non running Delorean.
There are good indications on my car, suggesting that it should start.
There's very little rust - probably because it was in an incredibly dry climate for it's first 12 years.
Then it seems to have been dry stored for the rest of it's life. so no water has got to it and no rodents have made it their home.
There are bad pointers too and they do pray on my mind .... but I'm more of a glass half full guy :-)
Postby Admin-bloke » Fri Mar 23, 2018 6:34 pm
Optimist: Glass is half full
Pessimist: Glass is half empty
Engineer: Glass is twice the size it needs to be
Postby gruffalo » Fri Mar 23, 2018 8:30 pm
Spudmurphy wrote:There are always risks when buying a non running Delorean.
I’m sure my misery won’t apply to your car :)
I just envious because you are making more progress than l do :D
Postby Spudmurphy » Fri Mar 23, 2018 9:29 pm
far from it ... I'm creeping along you are doing really great .... I'm running out of money lol
Postby bandit » Sat Mar 24, 2018 8:41 am
You need to stop paying so much tax :lol: :lol: :lol:
Postby gruffalo » Sat Mar 24, 2018 11:34 pm
I was close to getting the car roadworthy, but it ran on five cylinders only, and from that point on things went downhill pretty fast. But I hope to turn things around shortly .
