A list of things Ive done to the car (in no particular order) since I bought it 2 years ago. Ive probably missed a couple of things too but off the top of my head...
Fixed passenger mirror motor,
Changed the side mirrors,
New gear shift boot,
Fan over ride switch,
Rear fog light mod,
New rear tail light boards,
Added retrosound radio and used the craig faceplate,
New front speakers,
LEDs pretty much everywhere otherwise new lamps with added sidelight LEDs to the inner headlights,
Refurbed the HVAC mode select switch,
New struts all round,
New battery,
New rotor arm and cap,
New HT leads,
New spark plugs (NGKs),
New injectors complete with seals and clips,
New banjo bolts,
New valley heater pipe,
New heater valve,
Half of the coolant hoses changed,
New core plugs,
New starter,
New alternator (with brown wire reinstated),
Stainless heatshielding,
Freeflow exhaust,
All fuel lines swapped to SS braided ones,
New water pump,
New starter coil,
New accumulator,
New filters (air, oil and fuel),
New oil and coolant,
New fuel pump and boots, in-tank filter and hoses (tank cleaned too),
Cleaned the fuel sender but will replace once I get the Mckeen fuel gauge ECU (already have a replacement sender),
New window motors,
Refoamed the door cards,
Roofbox bolted down,
New headliners,
New crankshaft pulley seal (reinz) with new nut also,
New brake master (50:50),
New clutch slave,
New clutch line (SS braided),
New clutch reservoir hose,
Rebuilt all 4 callipers with new pins, pistons and pads etc,
New rotars,
New brake flex lines,
All circuit breakers, relays and fuses updated,
Trailing arm bolts (Inconel) and radius bushings changed for NOS,
Ali lower control arms,
British lower ball joints,
Lowered springs with new spring isolators,
New tie rods,
Sway bar powdercoated and poly bushings added,
Spax shocks,
Front hub bearings swapped for SKF ones with new retaining circlips,
Washer bottle repaired (kinda) with new washer motar and seal,
NOS Wiper stalk,
Coin tray replaced with Dgo (James') cup holder,
New tyres all round,
Switch mattaligner,
Silicone vac lines,
New inertia switch,
Headlight stainless 'L' brackets with ribbed finisher,
Stainless has had a good seeing to from Chris N so thats flawless with a full regrain to finish.
Still to do:
Weather stripping all round,
Steering wheel, binnacle, dash and seats to be recovered,
Wide stripe,
Side scoops (or delorean parachutes as Ive been told recently),
Lower strut reinforcement brackets,
Hood side trim pieces and seal/weather strip,
New rear speakers,
Other half of the coolant hoses to be swapped,
New radiator and condenser,
Aircon to be completly overhauled,
HVAC box refurbed,
Fascias and wheels to be repainted,
Steering rack refurbed,
Motorola alternator refurbed/rebuilt,
Rear hub bearings (also to be upgraded to SKF),
New passenger side center coolant pipe,
CV joints refurb,
Crank seal (transmission end),
New clutch kit,
New handbrake cables,
Tower brace (in the mail working its way from the states),
And anything else the car decides its had enough of in the mean time or Ive forgotten...
- 20210212_090804.jpg (6.76 MiB) Viewed 31488 times
