Postby Darrenre » Thu Sep 03, 2020 9:49 pm
A Van wrote:Difficult to say on the chains, personally if the car is staying outside and the headliners are very wet I would take them out now as they will retain moisture inside the car which you don’t want
And also I would unbolt the seats and get them indoors it’s a lot easier to work on the items you will be addressing with the seats out
Started down the headlining route, first hurdle are the sun visors! Think they have taken the brunt of water, screw heads turning to dust and the actual visor And metal bars are a mess. Will spray the seat bolts again tomorrow and give them a try too.
Darrenre
Postby Darrenre » Thu Sep 03, 2020 9:51 pm
eric wrote:Certainly an interesting one......It doesn't look too bad but so many things have rust which wouldn't usually have so much rust. The Chassis doesn't look too bad at all.
It really is as if its been wet and not dried out and flash rust has touched many elements.
Wasn't there something odd with the speedo ? last few digits unreadable, I initially thought there may be water damage in there ?
You mean my very low mileage! Not sure where the digits went!
Speedo
Darrenre
Postby jerzybondov » Thu Sep 03, 2020 10:02 pm
Darren - do you know what the history on this car is - when it was last run, where it was stored during its non-running period etc? Quite a project you've got there!
Postby MikeWard » Thu Sep 03, 2020 10:15 pm
Darrenre wrote:You mean my very low mileage! Not sure where the digits went!
Looks like a bit of foam has got back there blocking the last two digits, you'll need to take the binnacle apart to fish it out. It's sat at a little under 67k miles.
Postby andyd » Thu Sep 03, 2020 10:21 pm
Agreed, I think (quite apart from anything else), its a good idea to get the "soft furnishings" out at this point before they get sodden. With the seats out you can remove all the carpets etc and get down to the plastic tub. Also a chance to clean stuff up and see if its re-usable. You'll liek be inside the doors, so all that can come off till you see what you're working with.
The headliner and trim panels all come away fairly easily, but yes, the sun-visors may need you to be creative!
Good luck!
Postby Darrenre » Fri Sep 04, 2020 5:55 pm
jerzybondov wrote:Darren - do you know what the history on this car is - when it was last run, where it was stored during its non-running period etc? Quite a project you've got there!
It’s really odd. The car was sold and lived in California With two owners through 2006 up to 66,224 miles. A 26 year old bought it then and tooK it cross country to not so sunny Connecticut! He moved the car three times since then within the state according to the registration records before he sold it to BHCC with circa 66,824 miles.
The last location on the title Has a garage and plenty of room around it according to google Maps so not sure why it’s got so wet / surface corrosion.
I suspect it had winter outside as the rear of the engine / transmission casings are white. Although no sign of water in the fluids of engine and auto trans. Planning to hand turn the motor tomorrow !
Darrenre
Postby Darrenre » Tue Sep 08, 2020 10:25 pm
Well whilst my engine is most definitely seized, I have at least received my NOVA from HMRC so the car us all legit now awaiting It’s 40th birthday For registration.
No more water leaks noted also. Car going in a Carcoon soon pending new engine!
Darrenre
Postby eric » Wed Sep 09, 2020 11:35 am
Ahh thats a real bummer mate, I really had my fingers crossed for you.
Just looked up Carcoons, quite amazingly cheap, I paid 1/2 that for a good external cover. I may be tempted for one of them to stop the flaming cat/birds.
Postby eric » Wed Sep 30, 2020 2:14 pm
Positive review of Carcoon, I thought it may be flaming it initially but it beats the garage.
Re: VIN #2307 Engine Change Catch up
Postby Darrenre » Sun Jul 04, 2021 11:49 am
Just to bring everyone up to speed on my recent "kickstart".
Volvo Engine Finally removed
Volvo Engine Out
Delorean Engine and Auto Trans Removal
On its way out
Its out!
Driveline out
IMG_1070 2.JPG (3.95 MiB) Viewed 13814 times
Lovely Valley!
Valley Full of Crud
Now the fun part!
Swapping over
Swapping over
Darrenre
