Vin 3802 For Sale - £21,500 (unregistered) NOW SOLD
Re: Vin 3802 For Sale - £21,500 (unregistered) NOW SOLD
Postby Mark » Thu Mar 26, 2015 9:03 pm
A Van wrote:The relay is the best solution to enable four light braking wiring diagram coming v v soon
Excellent... Let me know when you have the wiring diagram ready, that would be great. Cheers! :thumbsup:
Mark
VIN #: 3802
Postby Horsebox » Thu Mar 26, 2015 9:31 pm
Oooooh that's interesting please tell more....is this a new relay we're talking about or a wiring mod to stock setup? Am intrigued!
Horsebox
VIN #: 06042
Postby A Van » Thu Mar 26, 2015 9:36 pm
New relay but one additional wire to stock
Postby A Van » Thu Mar 26, 2015 9:37 pm
We have several 'tech' articles on the way
Postby arranj » Thu Mar 26, 2015 9:38 pm
The best solution is based around replacing one of the dummy switches with a real switch, using the lambda light as the interior tell-tale, and making a modification to one of the tail light boards with a diode. Dan has done this most recently.
But what Alistair is talking about may be a slightly easier solution...?
Postby Horsebox » Thu Mar 26, 2015 10:00 pm
Brilliant. Can't wait to find out more. I modified mine to have an alien switch in the centre console and lost two of the brake lights in the process. Never been happy with the setup although it does the job. Good work...
Horsebox
VIN #: 06042
Postby Mark » Thu Mar 26, 2015 10:04 pm
arranj wrote:The best solution is based around replacing one of the dummy switches with a real switch, using the lambda light as the interior tell-tale, and making a modification to one of the tail light boards with a diode. Dan has done this most recently.
Do you replace the dummy switch with another Delorean switch? Did they do any other switches apart from the demister and window ones? Would be good to have the indication on the switch or in the instrument cluster... Lots to think about :)
Mark
VIN #: 3802
Postby Mark » Thu Mar 26, 2015 10:06 pm
Horsebox wrote:Brilliant. Can't wait to find out more. I modified mine to have an alien switch in the centre console and lost two of the brake lights in the process. Never been happy with the setup although it does the job. Good work...
Have you got any pics of your setup? Would be good to see for ideas. Cheers, Mark
Mark
VIN #: 3802
Postby Dan 6511 » Fri Mar 27, 2015 12:51 am
I did the diode solution. The idea originally came from Spratty. I'll do a diagram and post it up tomorrow. Its dead easy and no original wires have to be cut at all.
Postby Mark » Fri Mar 27, 2015 8:49 pm
Dan 6511 wrote:I did the diode solution. The idea originally came from Spratty. I'll do a diagram and post it up tomorrow. Its dead easy and no original wires have to be cut at all.
Sound good Dan, cheers :thumbsup:
I guess the diode is used to feed the centre lamps when the fog light switch is on while not activating the other brake lights. When the brakes are applied all the original brake lights illuminate.
Mark
VIN #: 3802
