Delorean for sale. #00944 Black Int. Manual. LHD
Postby InoX » Sun Jul 20, 2014 6:27 pm
VIN00944. Black Interior. LHD. Manual.
The car is currently laid up in storage.
Work done:
tyres Pirelli P6000 front p600 rear.
pads all around
rotors front
both fuel filters
stainless coolant bottle
DPNW coolant bleed kit on rad and bottle.
water pump (volvo bolt on)
stainless heater pipe installed in valley.
valley cleaned out and painted in POR 15.
silicone vacuum pipes.
led bulbs on dash.
new relays and fuses.
upper external door seals
front and back external door seals.
UK fog modification (switch and lamp)
front white side light modification.
fuel tank plate galvanised
brake booster
brake master cylinder
brake caliper rebuilds (PJ Grady).
both window motors replaced
DPNW lock solenoids and controller (that's the standard type, not the fancy remote one)
lock module modification (replaced relays and transistors, etc)
Work that needs doing
fuel hoses need replacing
engine doesn't idle great
front and rear bumper need refurbing
upper engine cover needs refurbing.
dent to left front fender (about the size of a 2 pence piece)
dent to left rear quarter panel (again about the size of a 2 pence piece)
binnacle needs refurbing. previous owner stuck something on it and the adhesive has marked the leather. not cracked or anything.
AC idle pulleys need re-attaching
AC needs charging.
upper windscreen finishing panel needs priming and painting.
and finally, as it's an early car, the panels need attention in terms of alignment. If you're an owner, you'll know what i mean.
Reason for selling is that due to work load and commitments, i can't get the time to bring it out of storage to finish the jobs off and enjoy the car.
I have all of the invoices for all the work done. V5 is present. The car is not MOT'd since it's in storage. You'd also have to think about a trailer or transporter to shift it.
Would like in the region of £20k for it. The car owes me more.
PM me if you're interested, or if you know someone who wants a car and doesn't mind a bit of work.
thanks for looking
Dave.
Re: Delorean for sale. #00944 Black Int. Manual. LHD
Postby RobvdVeer » Sun Jul 20, 2014 7:59 pm
I'm sorry to hear you are selling.
Postby InoX » Sun Jul 20, 2014 8:02 pm
it's alright I've got another one in the garage at my parents :) plenty of work still do do on that. It's just my priorities have changed...
I've also just remembered:
the car's had heated side mirrors installed and also a new fuel sender unit.
Postby lukebrynycz » Wed Aug 06, 2014 3:55 pm
If this was a grey interior I'd be interested :-(
lukebrynycz
Postby RobvdVeer » Wed Aug 06, 2014 3:59 pm
Perhaps could you add a few pictures for people to see what you are selling?
Postby wes1981 » Fri Aug 08, 2014 7:15 pm
hi dave
Are you able to post some pictures of the car?..If you can and want to chat could you email me at wes0117@hotmail.co.uk
thanks
wes
wes1981
Postby InoX » Mon Aug 11, 2014 8:52 pm
Hi
photos are available at the top of this photo stream.
https://www.flickr.com/photos/32731331@N04/with/14889062345/
They are of the exterior. No work done to the exterior, just the mechanics, as you can tell from the list above.
These are pictures from ages ago, but are representative of the car's appearance currently. I will upload some other pictures to hopefully(!!!) evidence the work I've done on it.
forgot to say it's got a Hervey 140A alternator and it's had toby tabs installed.
Sorry for the delay in replying. I've been uber busy with work and what not. (one of the reasons I'm selling)
Postby InoX » Sun Nov 23, 2014 8:02 pm
Hi!
car still for sale.
cheers
Dave.
Postby ALEXAKOS » Sun Nov 30, 2014 9:37 am
Can we have some frame shots?
Postby arranj » Sun Mar 22, 2015 3:06 pm
Hi Dave - are both of your cars still for sale? I will list on the new website if so.
