Throttle spool wanted
Re: Throttle spool wanted
Postby dmc4087 » Tue Jun 26, 2012 8:57 pm
The cable was actually made by a firm in Dublin a load of years ago. Maybe I should look at a new one from Dmch?
Postby dmc4087 » Tue Jun 26, 2012 9:01 pm
http://store.delorean.com/p-6495-throttle-cable.aspx
Is Steve Wynne going to eurotec? Can we put a request in?
Postby arranj » Tue Jun 26, 2012 9:07 pm
Both Stephen and Ed are going. Send them some emails! (quick!)
Postby bozzzydmc » Tue Jun 26, 2012 9:08 pm
He is :)
But if you think you need a new one let me know I have some already made up from pre stretched quality stainless cable with an end crimped and soldered on
You are very welcome to one
I would take the one you have out and give it a good clean . I would reinstall by covering it with normal chain oil
Postby dmc4087 » Tue Jun 26, 2012 11:30 pm
Sounds good Mike, how much are you looking for one?
The throttle cable in the car has always needed an extra spring on the spool so I'd like to get a standard one (or one made to proper oem specs). Oiling probably wont cure it.
Postby bozzzydmc » Wed Jun 27, 2012 7:14 am
Just get me a pint next time I see you :)
I will bring one at the weekend matey
Ps with the cable disconnected the pedal returns back up on its own ?
Postby dmc4087 » Wed Jun 27, 2012 10:06 am
Superb Bozzy, owe you one.
The pedal itself is fine.
With the throttle cable disconnected, everything was fine. But I didnt really suspect the cable as I said because it moves freely - so I had though the springs in the spool maybe werent great.
Postby dmc4087 » Wed Jul 11, 2012 4:14 pm
bozzzydmc wrote:Just get me a pint next time I see you :)
Update.
Bozzy's cable was installed last night, and some furthur tweaking of the throttle linkage was made, and I now have a returning throttle spool!...Almost lol, I still need a small spring but it comes back to idle and the pedal is soft so I'm happy.
Thanks Bozzy and co.
Postby bozzzydmc » Wed Jul 11, 2012 5:29 pm
Glad as a team we could help ;)
See you next month if your around for MervTec buddy
