Drivers Windows Motor
Re: Drivers Windows Motor
Postby dmc4087 » Mon Feb 25, 2013 7:49 pm
I might be interested, might help getting better discount with 2 sets ordered?
Postby asifmalik » Mon Feb 25, 2013 8:08 pm
Ricky is getting me prices. Ill comeback to you once I have them
VIN 1797, Twin Dealer Stripes, Dark Rims, Black Interior, Gas Flap, D-Locked, brushed by the master.
asifmalik
VIN #: 1797
Postby Dangermouse » Mon Feb 25, 2013 8:11 pm
arranj wrote:Size isn't important - .
Sometimes it is ;)
here is a little tip that might be worth knowing for this and other US-UK purchases:
The US Postal Service (USPS) has a set of fixed price flat rate branded boxes that can be very useful for mailing heavy items. E.g Small, Medium and Large
https://store.usps.com/store/browse/usp ... ernational
For example if you had 10lbs/4.5kg of DeLorean parts in a brown cardboard box, posting by weight at USPS would cost $81.
However, if that same 10lb fitted inside a USPS Flat Rate branded box, that would only cost $60. In fact you can ship up to 20lb max in that box for the same $60.
So in the OPs case, if he could stuff 20lb of motors-only in the Flat Fate box it could be quite economical. The physical size of the assembly will probably preclude that, though.
And why do I use the US Postal Service to mail a letter, whereas you use the Royal Mail to post a letter?
Postby asifmalik » Tue Feb 26, 2013 10:11 am
Riki has come back to me for 2 kits.
-15% discount and $127 for US Postal Service Shipping.
Is this a good price?
Works out at around £306 for each kit without the VAT and import duty.
asifmalik
VIN #: 1797
Postby MikeWard » Tue Feb 26, 2013 11:03 am
asifmalik wrote:Works out at around £306 for each kit without the VAT and import duty.
Crikey!
Edd China wrote:Because the window's are small, and the motor's are around £250 a pair, plus shipping. Owners don't always swap out broken or failing motor's.
And I thought £250 was expensive.
Postby asifmalik » Tue Feb 26, 2013 11:05 am
Check out the Euro price Mike! You will be shocked! :evil:
asifmalik
VIN #: 1797
Postby MikeWard » Tue Feb 26, 2013 11:22 am
£200 per motor?!?! :shock:
Does your A/C work? If it doesn't, I'd put the money into getting that working, it will do a much better job of cooling you than the crappy door windows, they may as well not be there for all the 'air' they bring in.
Postby asifmalik » Tue Feb 26, 2013 11:25 am
Hi Mike,
My AC doesnt work, what do you reckon it would cost to get the AC working nicely?
asifmalik
VIN #: 1797
Postby MikeWard » Tue Feb 26, 2013 11:53 am
You could get lucky and all it needs is a clean out and a re-gas.
Mine doesn't work btw, it needs a new A/C pump. For now, I make do with plugging the vent's to the doors to force maximum airflow out of the centre vents.
Postby Admin-bloke » Tue Feb 26, 2013 11:57 am
Depends if there is a leak in the system or not.. !
