replacement rear wheel bearing
Re: replacement rear wheel bearing
Postby marwood82 » Mon Jul 29, 2013 7:14 pm
A Van wrote:Can't see why they won't be ok, only a couple years use
I changed them as they became noisy... Probably after the thrashing it got at the Autotest event!
cool, i think it should be ok then
the only reason i was considering it was as the front brakes starting marking the disc maybe its over heated something.
given i need to get it roadworthy as soon as possible as im stranded in the uk until it is,
i think 2 rear bearings and 2 front discs is probably enough for now :-)
marwood82
VIN #: #11766
Postby A Van » Mon Jul 29, 2013 10:31 pm
Are the brake pads ok?
Postby marwood82 » Tue Jul 30, 2013 6:36 am
A Van wrote:Are the brake pads ok?
No. That's what's marked the disc. I picked up a set of the cortina ones from halfords
marwood82
VIN #: #11766
