Gaskets
Re: Gaskets
Postby ALEXAKOS » Fri Jul 04, 2014 9:07 am
jamesrguk wrote:I have that gasket set, I just need the main crank seal for the front of the engine the one which leaks between the engine an gearbox.
I have to say the sump gasket looks pretty thin, I'm with you that of it isn't leaking probably best not to change it.
James, I have added on mec's set the front seal you want. It is the orange one in the image. Ask mec if he doesn't need it, you may get it from him. :thumbsup:
