Door Latch Needed
Re: Door Latch Needed
Postby asifmalik » Thu Jun 23, 2016 4:03 pm
Thanks Arran, Order placed!
VIN 1797, Twin Dealer Stripes, Dark Rims, Black Interior, Gas Flap, D-Locked, brushed by the master.
asifmalik
VIN #: 1797
Postby asifmalik » Sat Jul 02, 2016 4:50 pm
Door latch fitted. Now some adjustment needed. Which rod do I adjust to allow the outside door handle open the door. At the moment I'm leaning in and pulling the bottom rod to get the handle to work.
asifmalik
VIN #: 1797
Postby minispeedstar » Sat Jul 02, 2016 9:38 pm
Follow this video
http://youtu.be/92JJQG57t1s
minispeedstar
Postby asifmalik » Sun Jul 03, 2016 12:11 pm
Thanks minispeedstar, Ill give that a shot
asifmalik
VIN #: 1797
Postby asifmalik » Mon Jul 25, 2016 2:01 pm
Don't know what i've done. Changed the latch, now the door won't open, either from the rods or by trying to force it from the outside or inside.
The window is down, and the rods are all visible.
What process do you guys recommend to get it to pop open?
asifmalik
VIN #: 1797
Postby RobvdVeer » Mon Jul 25, 2016 4:08 pm
This has helped me numerous times. The video is from the LH door.
Postby mknowlton » Mon Jul 25, 2016 6:39 pm
Hi Asif
There is a written DMC procedure for setting up the door locks and latches, if you pm me your e-mail address I will send it to you with a couple of important tips
Mike Knowlton (DBro 1)
DeLorean DMC-12, VIN#4208,
mknowlton
VIN #: 04208
Postby RobvdVeer » Mon Jul 25, 2016 7:09 pm
