RPM Relay Socket
Re: RPM Relay Socket
Postby bozzzydmc » Sun Sep 25, 2011 8:52 am
Nice info Dennis
And well done Rob !
RPM Relay Socket
Postby A Van » Sun Sep 25, 2011 9:18 am
+1 nice work!
Postby RobvdVeer » Sun Sep 25, 2011 6:22 pm
dmc-5180 wrote:Your RPM relay appears to have gotten HOT at some point. It might be worth getting a NEW one just to be safe. That same 6 spade connector is also the used for the Idle ECU.
You are right, I missed that. Thanks for the heads up. Perhaps it was the reason for the PO to ditch the existing socket. But when I got the car, more was wrong/melted/burned, eg. the inertia switch, the chimer box, and the fuse box. Somebody has some serious problems with the car i think. After I bought the car, me and my dad cleaned up a lot of bad wiring and connection points, never had any problem with it since.
