Can I borrow a wheel puller?
Re: Can I borrow a wheel puller?
Postby Rissy » Tue Sep 29, 2015 4:58 pm
If there's no difference between the two, then my method is correct, and in my opinion, simpler.
Anyway, horses for courses.
Good luck to all who get involved in the fix. :thumbsup: :mrgreen:
Rissy
May 1981 vin#1458
Grey Wheels
Grooved, flapped Bonnet
Black Leather Interior
Chassis: #1073
Engine: #2839
Main Car(s):
Rissy
VIN #: 01458
Postby Admin-bloke » Tue Sep 29, 2015 5:03 pm
Good post by Rissy about the steering wheel being centralised prior to adjusting the track rod end.
One thing to add, is centralise the rear wheels to the imaginary centre line of the car first, then set the front to rear along the same centreline.
Don't allow the garage to set the front to rear parallel thrust angles add the rear track is wider than the front and will finish up with offset wheel (5 degrees to the left) and bump steer. This is mainly for optical/ laser passive alignment.
Hunter alignment machines are great to prevent this, assuming that the operator has set "rim run out" compensation on and does actually adjust the rear....
Postby andyd » Tue Sep 29, 2015 8:37 pm
Thanks all, will check my lock to lock, and see what needs adjusting prior to Norfolk.
The car MUST be okay now, if I am faffing about with how the steering wheel sits! :jzd:
I also went and bought speakers today!! Never thought I'd get to the point where the terrible stereo sound was next on the to-do list... :shock: :lol:
And then build my boxes for the front footwells :dance:
(Haven't looked in the fuse box for a while... :whistle: )
A
Postby Daniel Shane » Wed Sep 30, 2015 7:52 am
Postby Rissy » Wed Sep 30, 2015 8:21 am
I used exactly this method this year to set up the front wheel alignment after a clutch change, gearbox rebuild and front shock replacement on my Honda Civic. Worked a treat. Never had to take it to the garage.
I've never done it on any other car.
Rissy
May 1981 vin#1458
Grey Wheels
Chassis: #1073
Engine: #2839
Main Car(s):
Rissy
VIN #: 01458
Postby Biff » Sat Oct 03, 2015 11:07 pm
Could someone post me a puller & I'll return it at the Norfolk meet?
PM for address and your paypal email for postage costs.
Cheers guys.
Biff
VIN #: 05127
Postby delorean12uk » Mon Oct 05, 2015 7:22 am
PM me your address and i'll have it in the post tomorrow, don't worry about postage costs, that's what the club is all about!!!
Postby andyd » Mon Oct 05, 2015 8:36 pm
OK, with the driving wheels dead ahead, I have 1 and (about) a quarter turns lock to lock each way.
Just the wheel sits a bit off centre at straight ahdeal and correspondingly is the same amount off at each of the stops.
So I reckon the wheel has been moved at some point. Which makes sense as the guy will have set the car for the road wheels (Hunter), and not been concerned about the steering wheel position. Makes sense.
I will get it sorted at "Steering wheel Tec"! :) (Thank you in advance!)
a
