WANTED - 1 Door Strut please.
Postby Admin-bloke » Wed Mar 24, 2010 12:21 pm
Hi all,
I am after a door strut for my drivers side that has gone a little bit limp (won't open the last couple of inches without a little lift)
My passenger side seems to be ok (although bounced a tiny amount at the end)
Wondering if someone has a good one going spare if they replaced a pair as a matter of course. It will save me being tight and trying to swap the struts over......
Thanks all.....
Re: WANTED - 1 Door Strut please.
Postby mnickels » Wed Mar 24, 2010 12:37 pm
Some spare came with my car but can't promise their condition if you want to try one
Postby Admin-bloke » Wed Mar 24, 2010 2:02 pm
That would be great :)
I'm in no rush for one, EuroTec event would be great if you could bring one along.
Postby mnickels » Wed Mar 24, 2010 2:39 pm
Remind me closer to the time
Postby arranj » Wed Mar 24, 2010 3:57 pm
I have one here too Mr Bloke. I've been keeping it here just in case anyone needed to reap its benefits* at some point! ;)
*Item is untested, old and probably knackered, but you never know. I'm sure I kept it for a reason! :?
Postby Admin-bloke » Wed Mar 24, 2010 4:19 pm
arranj wrote:I have one here too Mr Bloke. I've been keeping it here just in case anyone needed to reap its benefits* at some point! ;)
Always worth a go Arran ! At least we could rule it out if it's duff....
Postby DeLorean Cars » Wed Mar 24, 2010 5:34 pm
Arran, please never forget that one of the two ends on your driver's side has been shortened and must be swapped as and when you replace the driver's side strut.
Postby arranj » Wed Mar 24, 2010 5:44 pm
You have a good memory Martin! ;) But no - this spare one pre-dates the "modification" on my balls (at least I think it does), so should fit a standard D.
Postby mnickels » Wed Mar 24, 2010 5:46 pm
arranj wrote:You have a good memory Martin! ;) But no - this spare one pre-dates the "modification" on my balls (at least I think it does), so should fit a standard D.
This must be post of the week! Lol
Postby Admin-bloke » Thu Mar 25, 2010 12:52 pm
Also seeing if I can get one of Bozzys
viewtopic.php?f=35&t=1088&p=11251#p11251
