RPM Relay Socket
RPM Relay Socket
Postby RobvdVeer » Wed Aug 11, 2010 7:53 pm
PO removed the socket, now its just loose wires and spades. Does anybody know a brand/model replacement part? So such parts listed on normal vendor sites.
Re: RPM Relay Socket
Postby Admin-bloke » Wed Aug 11, 2010 7:57 pm
You can ask Dan and Gez and see if they can snip off the socket (and leaving some cable on it) from the car they are taking the engine out of........
Postby Dan 6511 » Wed Aug 11, 2010 7:57 pm
How about a plug cut off another loom, you could solder/heatshrink the wires onto your loom...?
Postby RobvdVeer » Wed Aug 11, 2010 8:18 pm
Dan 6457 wrote:How about a plug cut off another loom, you could solder/heatshrink the wires onto your loom...?
Brilliant. My search just went from a single socket to a single socket and a loom. :(
Postby Dan 6511 » Wed Aug 11, 2010 8:28 pm
We can probably cut one off the Volvo we are ripping the engine from.
Postby RobvdVeer » Wed Aug 11, 2010 8:42 pm
Smashing!
Its probably only a 0.20€ part so it should be available somewhere. Let me give EdU a ring too.
Postby RobvdVeer » Thu Aug 12, 2010 6:06 pm
Could this be it?
http://www.rdae.nl/multistekkers/multico...ts_id/1266
or
http://www.rdae.nl/multistekkers/multic ... ts_id/1202
Categorized as 6.3mm connectors. 2x3.
Edit: www.rdae.nl also stocks those hard-to-find bosch connectors to the WUR/CSV etc.
Postby Admin-bloke » Thu Aug 12, 2010 6:55 pm
Looks like the one.
The blade connectors are definately 6.3mm :)
Does this include the blade connectors themselves or is it ust the socket?
Postby RobvdVeer » Thu Aug 12, 2010 7:02 pm
The site sells different variations/combinations of the sockets. Male, Female, with/without pins.. There's a complete set for €2.00 i'll be checking it out. To save on P&P i'll put together a list of may-need items.
Postby bozzzydmc » Thu Aug 12, 2010 7:34 pm
Rob are the spades on the relay wires the type with the little 'tang' on ? If so then these will just push back into your new socket ...
