Mirror Switch
Mirror Switch
Postby ayr41 » Fri Jul 15, 2011 12:33 pm
Hi . Just wondered if anyone could help me out, I need the button you actually touch on the mirror switch to adjust the mirrors, perhaps someone may have a broken switch as I only need the button itself, thanks in anticipation ~ Stephen.
VIN Less
1974 VW JEANS BEETLE
ayr41
Re: Mirror Switch
Postby jerzybondov » Fri Jul 15, 2011 12:45 pm
If you're really struggling there is always this solution...
viewtopic.php?f=25&t=11&p=28737&hilit=saab#p28737
Mirror Switch
Postby A Van » Sat Jul 16, 2011 9:42 am
Hi Stephen
I know I did have a broken switch somewhere, will hunt around next weekend see if I can find it.
From memory don't know if you can just swap the top part without taking it all apart.
Re: Mirror Switch
Postby ayr41 » Sat Jul 16, 2011 10:41 am
Much appreciated Alistair would be great if you could find it, many thanks Stephen.
VIN Less
ayr41
Mirror Switch
Postby A Van » Sat Jul 16, 2011 11:53 am
I think Dan Stacey also went the Saab route, he may have a broken switch somewhere as well.
Re: Mirror Switch
Postby jamesrguk » Sat Jul 16, 2011 1:50 pm
if you happen to find 2 buttons them I'm still after one
James
Re: Mirror Switch
Postby jamesrguk » Sun Jul 17, 2011 1:56 pm
If someone can lend me a button I should be able to get my mate to cast some replacements in resin.
Mirror Switch
Postby Chriss » Sun Jul 17, 2011 5:35 pm
I thought I had a broken / parts switch but cannot find it at the moment although I did find a 'joystick' top if that's any use?
1981 DeLorean DMC12 VIN #6328
Re: Mirror Switch
Postby jamesrguk » Tue Jul 19, 2011 10:02 am
Chriss wrote:I thought I had a broken / parts switch but cannot find it at the moment although I did find a 'joystick' top if that's any use?
That's the part I need!
If I can buy/borrow it I should be able to get some more mad quite easilly.
James
Re: Mirror Switch
Postby ayr41 » Tue Jul 19, 2011 10:10 pm
Many thanks everyone now all sorted with the mirror switch a small part has made a big difference.
Regards
Stephen.
VIN Less
ayr41
