ARB wanted
ARB wanted
Postby andyd » Tue Aug 09, 2011 9:18 am
Hello all,
Does anyone have an anti roll bar they want shot of? Mine appears to be slightly bent :(
andy
Re: ARB wanted
Postby bozzzydmc » Tue Aug 09, 2011 9:20 am
Are you sure Andy ?
Would need to have taken a right clout to bend it ...
Re: ARB wanted
Postby andyd » Tue Aug 09, 2011 9:27 am
Agreed Mike.
(Bear with me, I'll try to explain)
Off the car, and laid flat, it should contact the floor at 4 points: the two location "lugs" at the front, and at the bends where it locates in the LCA's.
On the floor, mine contacts at 3 points, and can be rocked. One side is about half an inch off the floor, thus the rocking.
Hard to explain, will post photos in the other thread this evening...!
a
Re: ARB wanted
Postby bozzzydmc » Tue Aug 09, 2011 2:53 pm
Any way of bending it back ?
Re: ARB wanted
Postby andyd » Tue Aug 09, 2011 3:02 pm
bozzzydmc wrote:Any way of bending it back ?
I thought maybe... But thats a hell of a lot of force! More I suspect than my vice, weedy arms, and a scaffold pole can apply. Accurately! Thus my request for a good 2nd hand one. However, there is nothing to lose I guess. I wonder if Chris N may have one...
I will post pics tonight, but all advice, suggestions and comments appreciated.
Cheers mate
a
Re: ARB wanted
Postby delorean12uk » Tue Aug 09, 2011 3:46 pm
not being funny, but is the floor straight???
I wouldn't scrap the anti roll bar over a half inch error, BUT, I wouldn't bend it cold either, needs heat to rectify the problem correctly. where are you?? are you near Essex?? I can sort it for you if you want.
Re: ARB wanted
Postby andyd » Tue Aug 09, 2011 4:03 pm
delorean12uk wrote:not being funny, but is the floor straight???
Only reasonably straight!! but a good point. Will post photos later
delorean12uk wrote:where are you?? are you near Essex?? I can sort it for you if you want.
Feckin brilliant. Im in N12, but can probably borrow a car... Thanks, will drop you a PM (carrying an ARB on a motorcycle??! Sounds like fun!)
a
Re: ARB wanted
Postby delorean12uk » Tue Aug 09, 2011 8:48 pm
Andy, I work in Dagenham (RM9), do you want to drop it off there???
