Exhaust studs wanted
Postby dmc4087 » Fri Sep 30, 2011 12:13 pm
Does the club stock the brass studs anymore? I see the stainless, but I'd rather not put SS in the engine.
Thanks
Re: Exhaust studs wanted
Postby arranj » Fri Sep 30, 2011 12:21 pm
Brass nuts yes: http://www.deloreanclub.co.uk/parts/engine.htm - brass studs - no, we never have.
Postby dmc4087 » Fri Sep 30, 2011 12:33 pm
Ah right, not sure where my other ones came from then.
Postby bandit » Thu Oct 06, 2011 4:08 pm
Brass studs would be about as good as chocolate, they would snap. If you use stainless studs with brass nuts, that's fine
Postby dmc4087 » Thu Oct 06, 2011 4:27 pm
You're right, I meant brass nuts and steel studs.
I didnt fancy putting SS into the block but I got a set from Keith anyway.
Thanks
Postby delorean12uk » Thu Oct 06, 2011 7:44 pm
you wouldn't need SS studs and brass nuts together, pointless. Brass nuts and ferrous studs or SS studs and ferrous nuts. so they don't corrode together.
Postby Dan 6511 » Thu Oct 06, 2011 10:58 pm
I used zinc plated studs on my engine with stainless nuts.
