A few parts i need...
Postby OllieWilks » Wed Dec 05, 2012 1:36 pm
Hi All,
A big thanks again to J and TT for building the engine!!
I just need a few parts befre i can progress:
Does anyone have or know the best way to get:
Crank shaft pulley
Water pump pulley
2 x Tensioner pulleys for the air con belt
gear box bolts
the exhaust pipe from the manifold to the rear silencer
Thanks
Ollie
http://www.deloreanhire.com
OllieWilks
VIN #: 3928, 3185
Re: A few parts i need...
Postby arranj » Wed Dec 05, 2012 1:39 pm
Water Pump Pulley: viewtopic.php?f=102&t=2870
Postby tourettes tony » Wed Dec 05, 2012 7:48 pm
Get specific gearbox bolts, I've had a block where they were about 10mm too long and punctured the water jacket . TT
Postby delorean12uk » Thu Dec 06, 2012 5:44 pm
OllieWilks wrote:Hi All,
Crank shaft pulley
Water pump pulley
gear box bolts
Thanks
Ollie
Ollie, the tensioner pulleys for the air con are on the engine???
regarding the Cat bypass pipe, I definitely have not got it, I have looked everywhere, I thought that it was in the box(s) of parts when you originally came first time round. Sorry mate, if you haven't got it then I don't know where it is???
Postby bandit » Fri Dec 07, 2012 5:15 pm
Pulley posted today, might see it tomorrow Ollie
Postby OllieWilks » Fri Dec 07, 2012 8:50 pm
bandit wrote:Pulley posted today, might see it tomorrow Ollie
Thanks Julian!
[/quote]
regarding the Cat bypass pipe, I definitely have not got it, I have looked everywhere, I thought that it was in the box(s) of parts when you originally came first time round. Sorry mate, if you haven't got it then I don't know where it is???[/quote]
Yeah I don't have it I'm afraid mate. Luckily Ed does so have placed a hefty order with Ed :shock: and should get all that I need beginning of next week! :D
Might be a bit naive hoping this will be the last order made but I'll remain hopeful!
tourettes tony wrote:Get specific gearbox bolts, I've had a block where they were about 10mm too long and punctured the water jacket . TT
Thanks for tip mate, have got these ordered as well.
OllieWilks
VIN #: 3928, 3185
