A few bits wanted!
A few bits wanted!
Postby OllieWilks » Wed Feb 06, 2013 10:58 pm
Hi there,
Has anyone got a starter motor and/or alternator they could sell me?
I think I also need two exhaust brackets.
Thanks for looking
Ollie
http://www.deloreanhire.com
OllieWilks
VIN #: 3928, 3185
Re: A few bits wanted!
Postby OllieWilks » Thu Feb 07, 2013 10:00 am
Please could someone confirm whether these would be the right ones?
http://www.ebay.co.uk/itm/330809119134; ... 26_rdc%3D1
http://www.ebay.co.uk/itm/200877481038? ... 26_rdc%3D1
Many Thanks!
OllieWilks
VIN #: 3928, 3185
Postby A Van » Thu Feb 07, 2013 10:30 am
We might have the right ones in stock
Postby Admin-bloke » Thu Feb 07, 2013 10:34 am
Stattet motor looks ok. Verify with seller if it is compatible with the b28 v6 engine.
However I think the club has one in Stock.
The alternator is not powerful enough. I recommend the high output one at least 140 amps.
Postby arranj » Thu Feb 07, 2013 12:53 pm
We do have a starter motor in stock: viewtopic.php?t=2486 - but it is £180 plus postage :shock: - The one on Ebay - is it for a 2.8 litre engine? - but with a bit of research, I'm sure you can find the right one if that isn't it. Renault may be easier to search for. Here is a start: viewtopic.php?f=25&t=260
You could also try Dave Howarth: viewtopic.php?f=35&t=201
As for the alternator, I know Stuart in Banbury was able to get one using this page and his local motor factors: viewtopic.php?f=25&t=2213 - the original was 90amps, but yes you want at least 105 or 110 amps - you won't get 140 amps in this country. There are loads of Renault alternators that fit, start with a Renault 25 and go from there. Follow the links on that page.
Postby OllieWilks » Thu Feb 07, 2013 2:11 pm
Thanks all for your help! Much appreciated!
Have spoken to Dave and he has a starter motor and is going to try and locate an alternator as well.
Is there an alternator available through the club if not? I'll keep searching the web as well.
Thanks for the links!
OllieWilks
VIN #: 3928, 3185
Postby arranj » Thu Feb 07, 2013 2:15 pm
We used to, but not any more. If you follow this link: viewtopic.php?f=25&t=2213 - there are a couple of working sources on there. It's not too hard to find one.
Postby arranj » Thu Feb 07, 2013 2:28 pm
Postby Daniel Shane » Thu Feb 07, 2013 5:34 pm
Goto a renault dealer and ask for a starter and alternator from a 2.8 V6 Safran.
Postby arranj » Thu Feb 07, 2013 8:00 pm
Oh, and we do have exhaust brackets in stock. These ones though: http://www.delorean.eu/catalog/product_ ... s_id=45025 - £40 each...
