Wanted Urgently: Fuel Pump Relay
Postby OllieWilks » Wed May 22, 2013 1:51 pm
Hi All,
Has anyone got or could tell me the best place to get a fuel pump relay? Seem to be out of stock unfortunately?
Really need to get one asap.
Thanks! :)
http://www.deloreanhire.com
OllieWilks
VIN #: 3928, 3185
Re: Wanted Urgently: Fuel Pump Relay
Postby OllieWilks » Wed May 22, 2013 2:00 pm
Think im going to order a volvo 760 one. Would this work? Cheers
OllieWilks
VIN #: 3928, 3185
Postby Daniel Shane » Wed May 22, 2013 2:14 pm
You can make one using a normal relay, a relay base, some wire and some crimp spade connectors.
Postby arranj » Wed May 22, 2013 5:55 pm
OllieWilks wrote:Think im going to order a volvo 760 one. Would this work? Cheers
This one - can't say I have personal experience. I know Dan 6457 did though: http://www.ebay.co.uk/itm/360380583225
Postby Admin-bloke » Wed May 22, 2013 6:42 pm
You could always do the link as a temporary measure:
http://www.specialtauto.com/delorean-pa ... jumper.jpg
You can replace the 555 timer chip on your original one or get the one from euro car parts or buy one direct from Ed/ Houston.
This as assuming that it is the fuel pump relay that is at fault.
The earth side of the pump goes via the inertia switch so make sure this is in place and the plunger is in the down position.
Postby bozzzydmc » Wed May 22, 2013 6:53 pm
I have a spare you need it quickly :)
Postby arranj » Wed May 22, 2013 7:15 pm
What's the rush? Isn't the car in pieces?! ;)
Postby OllieWilks » Wed May 22, 2013 9:49 pm
Thanks all for the comments.
Dropping bozzy a pm.
arranj wrote:What's the rush? Isn't the car in pieces?! ;)
A lot less pieces than it was ;) hoping to MOT it any day now. Just trying to work out a few bugs.
OllieWilks
VIN #: 3928, 3185
