A Van wrote:Can't see why they won't be ok, only a couple years use
I changed them as they became noisy... Probably after the thrashing it got at the Autotest event!
cool, i think it should be ok then
the only reason i was considering it was as the front brakes starting marking the disc maybe its over heated something.
given i need to get it roadworthy as soon as possible as im stranded in the uk until it is,
i think 2 rear bearings and 2 front discs is probably enough for now
