Butterfly assembly 102856
Postby dmc4087 » Sun Apr 20, 2014 2:45 pm
Hi all,
Would anybody have this part lying around? The return spring on mine is knackered and I dont see it listed separately on DMCH website. Might be easier to change the lot?
Thanks
Re: Butterfly assembly 102856
Postby jwrayth » Tue Apr 22, 2014 12:12 pm
I don't believe you can change just the spring, you have to replace the whole assembly.
jwrayth
VIN #: 4494
Postby Dangermouse » Tue Apr 22, 2014 1:19 pm
This might be an interesting read Thomas
http://delorean6575revisited.blogspot.c ... embly.html
Postby dmc4087 » Tue Apr 22, 2014 5:37 pm
Sorted thanks to Admin-Bloke
Postby dmc4087 » Tue Apr 22, 2014 6:33 pm
Dangermouse wrote:This might be an interesting read Thomas
Cheers Dermot, must compare the two units when the new one arrives to see what the springs are like.
Postby delorean12uk » Tue Apr 22, 2014 8:20 pm
dmc4087 wrote:Hi all,
Thanks
do you still need throttle body???? I have a few lying around at home if you need one
Postby dmc4087 » Tue Apr 22, 2014 8:29 pm
I have a used one on its way, if its no good I'll give you a shout. Thanks!
