Grey passenger side carpet pieces required
Postby Max Power » Mon Nov 03, 2014 1:42 pm
I need 2 pieces of original grey carpet,mine has been eaten away by a battery acid spill.The bit I need is passenger side under the seat and piece by the inner sill.The rest of the carpets are fine so reluctant to buy a complete set.
So if anyone is replacing a set is has done so and kept the old bits just in case I'd be glad to hear from you.
Regards Max
Max Power
VIN #: #20032
Re: Grey passenger side carpet pieces required
Postby A Van » Mon Nov 03, 2014 2:41 pm
Hi Max
I have just checked my old set of grey carpets, and I don't know why I have kept them they all need throwing away,
I think Mike Ward is changing his soon, could try him?
Postby MikeWard » Mon Nov 03, 2014 2:59 pm
A Van wrote:I have just checked my old set of grey carpets, and I don't know why I have kept them they all need throwing away,
They will probably clean up OK Al, if they are not worn then a clean and re-dye should sort them.
A Van wrote:I think Mike Ward is changing his soon, could try him?
I was going down the route of changing them as I didn't think the drivers side carpet could be saved (owing to the clutch master leaking into the footwell and staining it brown):
But after a clean it has come up really well:
I'm going to re-dye the carpets at some point over the next week or two, will post up some shots once complete.
Postby A Van » Mon Nov 03, 2014 4:29 pm
They are worn, basically whatever isn't ripped or worn is badly sun damaged I don't think even a re dye would work
Postby jerzybondov » Mon Nov 03, 2014 4:53 pm
Mike - that carpet looks great. What did you use to clean it?
Postby Markymark » Mon Nov 03, 2014 5:11 pm
I have bits of dark grey but not the one behind the seat where the battery box is.
Mark Bourne
Markymark
Postby MikeWard » Mon Nov 03, 2014 5:21 pm
jerzybondov wrote:Mike - that carpet looks great. What did you use to clean it?
My friend does carpet cleaning for a living, so I gave him all of the carpets to run his machine over. The drivers side was the one i was worried about as it had the brake fluid staining on it, all the others just had general dirt on them.
They all came up really well, obviously the main ones are the foot well pieces:
I guess a Rug Doctor would be something similar to what my friend uses.
Once I get them back, I am going to dye them, hopefully they will then look good as new, and thats a significant amount of cash saved by not having to buy a new carpet set.
Postby Max Power » Mon Nov 03, 2014 7:41 pm
Markymark wrote:I have bits of dark grey but not the one behind the seat where the battery box is.
The only bits I need are the the one under the passenger seat and along the inner sill passenger side.
Max Power
VIN #: #20032
Postby Max Power » Mon Nov 03, 2014 8:10 pm
A bit beyond a clean up!
Max Power
VIN #: #20032
Postby BABIS » Mon Nov 03, 2014 8:16 pm
well if there is more than one set available I need also a passenger footwell carpet and the one that covers the battery box (parts 110464 and 110480) in light grey ;)
http://store.delorean.com/c-318-8-7-2-carpets.aspx
BABIS
