Engine wanted
Engine wanted
Postby carldenonde » Thu Jan 29, 2015 12:05 am
I live in Norway and bought my Delorean from the US three years back. But when they shipped it, the temperature in Norway was -10 degrees. And the car, from Georgia, had no anti-freeze fluid in it. So the engine has gotten worse and worse and now it has no compression on three of the sylinders. Both on top, in the middle and the bottom of the sylinders. So I guess the engine block is raptured.
So I'm looking for a new engine. Have been looking for an old Volvo in Norway and Sweden, but with no luck. But I'm still looking.
So if anyone knows of an engine somewhere, please let me know.
(and excuse any mistakes in technical explainations, I barely know the Norwegian terms)
Carl
carldenonde
Re: Engine wanted
Postby jamesrguk » Thu Jan 29, 2015 12:17 am
Hi Carl,
I'm sure you'll find help on here, have you spoken with Ed Uding at DeLorean Europe www.delorean.eu he may have access to second hand engines too.
ta
james
Re: Engine wanted
Postby carldenonde » Thu Jan 29, 2015 2:10 am
I have sent him an email, but his motors look quite expensive.
Carl
carldenonde
Engine wanted
Postby ALEXAKOS » Thu Jan 29, 2015 8:37 am
carldenonde wrote:I have sent him an email, but his motors look quite expensive.
Carl
Then look in the french classifieds
http://Www.leboncoins.fr
Plenty PRVs show up in there ;)
For assistance contact our fellow French member Domi. I am sure he will be happy to help;)
Re: Engine wanted
Postby Admin-bloke » Thu Jan 29, 2015 10:56 am
Why not take your engine out and take it apart to see what the actual problem is. It could be something simple like a slipped timing chain on one bank, blown cylinder head gasket etc.
You can get spate gaskets as a full kit.
Even if the pistons and bore are damaged, they can be replaced. Someone in here has spats to build an engine. It is usually the main block that corrodes. If this is ok then you can just do a rebuild. .
Re: Engine wanted
Postby Admin-bloke » Thu Jan 29, 2015 10:57 am
If you do finish up putting in a different engine, don't throw anything away, someone will want the parts
Re: Engine wanted
Postby carldenonde » Thu Jan 29, 2015 4:52 pm
I'm not very good with engines, so a total rebuild will be difficult. An engine swap would be possible... hopefully. I guess I have to check the french site.
And I'll never throw anything away. Will probably need the spare parts for myself in the future... ;)
Carl
carldenonde
Re: Engine wanted
Postby carldenonde » Thu Jan 29, 2015 5:05 pm
Must say I didn't quite get this site. Just get loads of ads. Does it have an IQ control or something? Mine is obviously to low...
Carl
carldenonde
Re: Engine wanted
Postby Chris Hawes » Thu Jan 29, 2015 7:21 pm
Regards,
Chris Hawes
Chris Hawes
VIN #: Ex owner of 5255
Re: Engine wanted
Postby A Van » Fri Jan 30, 2015 11:45 am
I might know of a Volvo engine for sale
