Can I borrow a wheel puller?
Postby Biff » Mon Sep 28, 2015 9:03 am
Morning, I'd like to sort/investigate the indicator non-cancelling problem on my D.
Anyone kind enough to let me borrow their steering wheel puller.
Of-course, I'll paypal postage costs.
Cheers m' dears.
Biff
VIN #: 05127
Re: Can I borrow a wheel puller?
Postby DJK73 » Mon Sep 28, 2015 9:56 am
I just done this job on my car
i made my own puller, I can show you how or post it to you, or are you coming to norfolk? I can bring it then
Dbro4
Ex Vin#10223
Grey interior, Manual
Free flow
DJK73
VIN #: 10223
Postby delorean12uk » Mon Sep 28, 2015 10:55 am
i've got one as well, if your going to Bas Vegas I can sort it for you then???
Postby Biff » Mon Sep 28, 2015 12:31 pm
Thanks for kind offers, I wasn't planning on Norfolk, but is there any room left? Costs? When? Where...........
I know, I'll go look for thread......... :think:
Biff
VIN #: 05127
Postby arranj » Mon Sep 28, 2015 1:25 pm
viewtopic.php?f=32&t=4759
October 16th 2 nights.
Yes, room left here: http://www.abacushotels.co.uk/knights-h ... l-and-spa/ - which is 3 miles away, although we'll transport you back for free once the bar is closed each night.
Postby andyd » Mon Sep 28, 2015 1:48 pm
DJK73 wrote:I just done this job on my car
Hi Guys
Could someone bring one please? I would like to move my wheel round a spline or two.
I have had the car aligned (Hunter), but it would appear that perhaps the wheel was not *quite* centre when it was done.
I understand I should probably do this at the TRE's, but as it tracks perfectly, and handles well now, I would rather not cock it up and just move the wheel... (tho I haven't actually checked the turns lock to lock, so it may just be that the wheel is in fact a spliine or two out...)
Norfolk would be ideal... Anyone know the nut size??
More beer to buy!
a
Postby DJK73 » Mon Sep 28, 2015 2:05 pm
I'll bring my puller etc to Norfolk no problem
Dbro4
Ex Vin#10223
Free flow
DJK73
VIN #: 10223
Postby Rissy » Mon Sep 28, 2015 2:27 pm
You'll not get nearly the same degree of finality in trying to adjust alignment through moving splines on the wheel, or the shaft for that matter either.
Adjustment is much more subtle doing it the correct way. As you say, at the TRE's and rack adjustment. I'm sure you'll just be faced with frustration trying to do it through the wheel. The fact you need a heavy duty tool to free off the wheel should be indication enough that this is not the way to do it. Anyway, you're obviously fully aware.
Good luck.
Rissy
May 1981 vin#1458
Grey Wheels
Grooved, flapped Bonnet
Black Leather Interior
Chassis: #1073
Engine: #2839
Main Car(s):
Rissy
VIN #: 01458
Postby andyd » Mon Sep 28, 2015 3:00 pm
Am I right in thinking that as long as I turn each track rod (in the right direction!) by the same number of turns (in the right direction) then the front wheels will remain correctly positioned in relation to the rears??
And how do I know that the steering wheel is correct on the splines? By counting the lock to lock, dividing by 2, and thats centre?
Finally, am I right in thinking that once the lock nuts are loosened, I can just turn the track rods? I dont need to break the taper and actually turn the TRE do I??
a
Postby DJK73 » Mon Sep 28, 2015 3:27 pm
If a PO has messed with your steering wheel then you may have to reset it to get the indicators to cancel
Mine had been totally messed with and could not be done by adjusting the TREs
Any way as I said I have tool and any body that wants to borrow it at Norfolk is more than welcome
Rissy perhaps you can bring your tools and help out as well ?
Dbro4
Ex Vin#10223
Free flow
DJK73
VIN #: 10223
