Looking for some parts
Postby Slammer » Thu Nov 12, 2015 9:16 pm
HI.
This is some of the parts I know I'm missing
Window guides in drivers door (I have an extra set for the rh door)
Park brake sleeve
Toolbag/jack
Spare wheel
Park brake sleeve
Radiator duct
Mirror sw adjuster and blanking cap
PM if you have anything to sell.
Slammer
Slammer
VIN #: 06201
Re: Looking for some parts
Postby A Van » Thu Nov 12, 2015 10:08 pm
Might have toolbag and Jack will check ,
Postby Slammer » Fri Nov 13, 2015 5:28 am
A Van wrote:Might have toolbag and Jack will check ,
Sounds good.
Slammer
VIN #: 06201
Postby Slammer » Sun Dec 20, 2015 7:10 pm
Update.
Spare wheel is on it's way.
Purchased a universal jack.
Still looking for these parts:
Park brake sleeve
Radiator duct
also missing a ton of other parts, but I will buy them new.
Slammer
VIN #: 06201
Postby Admin-bloke » Sun Dec 20, 2015 7:21 pm
Which guides in the drivers window, the bit at the top of the stainless bit of the door or the seal that the window slides in when it's moved to the up position?
Postby Slammer » Sun Dec 20, 2015 9:28 pm
Admin-bloke wrote:Which guides in the drivers window, the bit at the top of the stainless bit of the door or the seal that the window slides in when it's moved to the up position?
Front and rear guide for the drop glass.
http://store.delorean.com/p-7067-guide-front-lh.aspx
Slammer
VIN #: 06201
Postby Slammer » Mon Feb 06, 2017 10:25 pm
Still looking for a park brake sleeve
http://store.delorean.com/p-7433-prk-brake-sleeve.aspx
Slammer
VIN #: 06201
Postby arranj » Tue Feb 07, 2017 12:34 am
One here if you're feeling flush..... :shock: http://www.ebay.co.uk/itm/122319683614
I would buy the rest of the assembly off of you, but for less than half that price. A lot of that guy's prices are a bit - erm - steep - to say the least - and he doesn't haggle.
Postby Slammer » Tue Feb 07, 2017 5:31 am
I have seen that one, but do not really want to spend $160 +$70 +VAT for the part if I can avoid it.
Slammer
VIN #: 06201
Postby jwrayth » Wed Feb 08, 2017 10:09 am
Slammer wrote:I have seen that one, but do not really want to spend $160 +$70 +VAT for the part if I can avoid it.
Even if you needed the full assembly that price is crazy! The bracket that attaches to the tub has snapped studs there, so it'd be total cost + removing the old studs and welding in new ones.
jwrayth
VIN #: 4494
