Piston liner paper seals wanted
Postby Dan 6511 » Mon Jan 25, 2016 2:20 pm
Hi,
Are the paper seals that seal the liners to the block available over here?
I was looking online and apparently Josh Bengston sells stainless ones?? How can they possibly seal if they are metal?
Cheers,
Re: Piston liner paper seals wanted
Postby delorean12uk » Tue Jan 26, 2016 8:11 am
most gaskets on modern engines are made from a shim type material now. Personally though, knowing what the alloy is like on the block, I would make sure both the block and liner material on the mating faces are clean of any corrosion or debris using scotchbrite or something similar. and I would use the paper gaskets sealed with Hermatite blue or Hylomar on either side . what colour gaskets do you need???
Postby Dan 6511 » Tue Jan 26, 2016 10:34 am
Talking to the engine guru, mr tourettes recons to use yellow ones.
I have just found that Ed sells them and dirt cheap too :)
I might not need them bits off you anymore jason as I found the block is rotten. So I have stripped down my other engine now and hopefully that has a good block and crank and I can make one good one out of all the bits.
I'm thinking about getting the heads rebuilt while they're off and I already have new valve seals that I can use. Anyone got a recommendation of someone that can do them?
Postby mec » Tue Jan 26, 2016 12:30 pm
i used the place that TT recommended for my heads to be skimmed, elmsleigh engineering i think was the name, i assume they could go through them as well, or you could go the performance route and them gas flowed and stuff !
Postby Dan 6511 » Tue Jan 26, 2016 2:11 pm
Cheers for that Mec, I'll give them a call and see what they can do :) I won't worry about performance mods though as its still a delorean ;)
I'd do them myself (apart from skimming) but haven't got the time because of work and I really want this thing working again in time for eurofest.
