Idle ECU
Idle ECU
Postby Ivko » Mon May 15, 2017 8:14 pm
hello again :)
my idle ecu is bad and so i´m looking for another one. can i take it from an peugeot, renault or volvo? and what part numbers would fit?
thanks
-Ivko
Ivko
Re: Idle ECU
Postby A Van » Tue May 16, 2017 9:08 am
Hi
Are you sure its definitely faulty? What are your symptoms v
It is unique to the DeLorean from memory the volvo one has different connectors
Re: Idle ECU
Postby DMCD » Tue May 16, 2017 3:33 pm
I Highly recommend Dave Mckeen's modern unit. You can set the ECU idle anywhere from 750 to 950, and the unit is really good for setting your curb idle screw - it includes an LED that tells you when the ISM is closed. It also gets rid of the idle hunting when the car is cold. Oh and it'll cost you under $150.
DMCD
VIN #: 4285
