A/C idler pulley & door grab handle backing
Postby InoX » Sat Sep 02, 2017 6:03 pm
hiya
I'm after an A/C idler pulley and two of the door grab handle pulley backing things. Two of these:
but in black.
just on the off chance someone has these in a box some place. Mine have gone walkies :oops:
cheers!
Dave.
Re: A/C idler pulley & door grab handle backing
Postby arranj » Sat Sep 02, 2017 7:23 pm
As well as that one, I also have a pair of them in grey (used) - each side is different, nothing in black I'm afraid - that's the rarer one.
Pulleys here, if you don't find a used one: https://www.deloreango.com/uk/idler-adj ... ulley.html - it's a part unique to the car I'm afraid - originally made by "Tony Scott Engineering"
Postby InoX » Sat Sep 02, 2017 7:42 pm
cheers for that. don't know where they went. I know i knackered the pulley trying to press out a bearing years ago, but now seem to have misplaced the entire bracket spindle spacers and washer.
The grab handle things - god knows where they went. im sure they must have been on the car at some point, think i removed them when i replaced the door lock solenoids in 2007. Moved house since. I'll try the shed then maybe ask colleagues over the pond if there are any available over there..
might opt for the pulley from you if i don't get owt here. ta.
Postby arranj » Sat Sep 02, 2017 8:57 pm
InoX wrote:cheers for that. don't know where they went. I know i knackered the pulley trying to press out a bearing years ago, but now seem to have misplaced the entire bracket spindle spacers and washer.
I think I have everything in that section - it's all on the "to do" list. If you let me know the part numbers of everything you need I will list it up.
Postby InoX » Sun Sep 03, 2017 5:10 pm
Hiya
thanks for that.
SP10376 - cir clip x4
105470 - pully spindle x1
100773 - PULLEY MOUNTING BRKT x1
105471 - SPACER, A/C COMP x1
106257 - SPACER, IDLE BRACKET x1
SP10806 - LOCKNUT M12 x1
106161 - SPACER, SHORT IDLER x1
also you don't have any of these do you?
108720 SUPPORT BUFFER RH
108721 SUPPORT BUFFER LH
http://store.delorean.com/c-311-8-4-3-engine-compartment-cover-upper.aspx
cheers
Dave.
Postby arranj » Sun Sep 03, 2017 5:32 pm
SP10376 - circlip x4
Are in stock, I will list them up today, should be searchable under those numbers then.
105470 - pulley spindle x1
I will pick these up in Holland this coming weekend. They will appear for sale by a week on Tuesday at the latest.
108721 SUPPORT BUFFER LH (these are actually both the same part, trim to suit)
These are already on the site anyway, just type those numbers into the search box
Postby InoX » Sun Sep 03, 2017 6:14 pm
cheers for that.
while you're over there you couldn't get me the upper screen finisher, could you? :D :whistle: :mrgreen:
Do you want me to put an order in for anything now for deposit or anything? got some other bits to get. The car's turning into trigger's brush.
