0-60 Videos no numbers, no dyno, just FACT
Re: 0-60 Videos no numbers, no dyno, just FACT
Postby RobvdVeer » Fri Mar 05, 2010 10:25 pm
Ever wondered why there's 'man' in manual? Nonono auto is not an elite group. Its the easy way out. (Fishing for responses!)
Postby delorean12uk » Fri Mar 05, 2010 10:48 pm
RobvdVeer wrote:Ever wondered why there's 'man' in manual? Nonono auto is not an elite group. Its the easy way out. (Fishing for responses!)
you just bought a manual because it's got a gearstick and you've got nothing else to fiddle with!!! good enough response for ya!! :P
Postby RobvdVeer » Fri Mar 05, 2010 10:51 pm
delorean12uk wrote:you just bought a manual because it's got a gearstick and you've got nothing else to fiddle with!!! good enough response for ya!! :P
Oh yes
Postby jamesrguk » Sat Mar 06, 2010 9:59 am
Dan 6457 wrote:Cool. If you wanna go for a race down the A120 James, let me know. We both have the
same setup volvo wise, so it would be a straight auto v manual test.
Yeah it would be great to do a side by side comparison, i'd expect the manual to be quicker obviously, but it
would be interesting to see 1st hand how much quicker it is.
I often have days of during the week so if you're ever at a loose end and your car is on the road drop me an
e-mail and we can do some basic tests.
A few side by side tests 0-60 and then say side by side at 30mph and then floor it to 70mph to see how they
differ in that speed range.
I guess the auto will mainly loose out on the 0-15mph as the gearing in 1st seems quite tall and the torque
converter isn't 100% efficient + obviously there are only 3 ratios to choose from.
I'm going to do a much needed oil change on Monday and then do a couple of other tests with the camera
fixed on the speedo.
off topic, but which filter do I need from Halfords and what oil? 100% synthetic?
Postby Admin-bloke » Sat Mar 06, 2010 11:27 am
viewtopic.php?f=16&t=2
Oil Filter
CRO 659
MAHLE OC 266
(Approx £2.50 NB: This has the anti drain back valve inside.
The diameter is correct to avoid a standard oil sender.
The flow capacity correctly matches the engine)
FRAM PH 2964
Unipart UGCGFE173
HALFORDS OWN BRAND - HOF206
OIL: 15w/40 Semi Synthetic is fine. I personally wouldn't go for a fully synthetic it will be too thin.
Change once a year regardless of mileage.
Your car your choice though. :D
