Postby mnickels » Mon Mar 15, 2010 6:48 pm
RobvdVeer wrote:I keep being surprised by the fact that you do all this in that eeny teeny garage..
Size doesn't matter. It's what you do with it that counts. So Nick T tells me anyway ;)
Ireland Rep
mnickels
VIN #: 2456
Postby Admin-bloke » Mon Mar 15, 2010 9:35 pm
Cheeky !
Postby mnickels » Sat Mar 20, 2010 9:24 pm
Gearbox is just about ready for painting after today. Need to get one of the wee rubber yolks that the dipstick is secured in with. Sandwich plate removed from old engine for Dan and sump removed to be transferred across.
How is the oil filler on the aircon rocker cover removed. I want to use the one on my new rocker cover as it is a screw top and shiney. Is fixed on inside but not sure what they are
Ireland Rep
mnickels
VIN #: 2456
Postby A Van » Sun Mar 21, 2010 6:04 pm
Matt, are you referring to the insert on the gearbox?
Postby mnickels » Sun Mar 21, 2010 6:23 pm
A Van wrote:Matt, are you referring to the insert on the gearbox?
Yes m8
Ireland Rep
mnickels
VIN #: 2456
Postby A Van » Sun Mar 21, 2010 6:32 pm
I have one or maybe two in the spare boxes...but years ago a French guy found that the plastic otterstat insert was a perfect fit and stopped it from leaking.
Postby mnickels » Sun Mar 21, 2010 6:38 pm
A Van wrote:I have one or maybe two in the spare boxes...but years ago a French guy found that the plastic otterstat insert was a perfect fit and stopped it from leaking.
Would be good if you could sort me out with one m8
Ireland Rep
mnickels
VIN #: 2456
Postby mnickels » Mon Mar 22, 2010 6:24 pm
Some pics from today
Chassis prep
Pontoon paint test
Pontoon painting
Gearbox painting
Ireland Rep
mnickels
VIN #: 2456
Postby bozzzydmc » Mon Mar 22, 2010 9:29 pm
WOW !!!
Bloody great job Matt !
Postby mnickels » Tue Mar 23, 2010 7:04 pm
Today I finally got a response from a mobile welder who is calling tonight to see what needs done. I fitted the old sump to my new engine, drilled the 6mm holes on my old rocker covers out to 8mm and fitted the old rocker covers. Removed the old gasket material from the rocker covers and sump, what a job that was! Broke down my front suspension and brake assemblies. Boxed up my calipers to be sent for refurb. Finally I fitted my air con compressor to the engine.
Ireland Rep
mnickels
VIN #: 2456
