Postby A Van » Sun Oct 31, 2010 8:12 pm
Good work Gez, shame on Kwik Fit... I can see its wound you up a bit!
Postby tourettes tony » Sun Oct 31, 2010 9:29 pm
I hate to say it but it may all be down to the cam's which is why volvo didnt use that profile, if you cant fix the problem you may have to pick an MOT station that doesnt do Emissions :(
Postby jerzybondov » Mon Nov 01, 2010 7:28 pm
Well, took myself down to another local garage today on the hope of getting a pipe stuck up my bum for free, so to speak. Not free, but for £20 they would run through the MOT program on the computer and find out whether my car would pass or not.
Once the car was properly warm we went for it, revved it up to 2500rpm for 20 secs to purge it, then whack the pipe in and see what the HCs come back to in the next 15 secs or so. Answer: 637. It's a pass! Strangely the car had leaned itself off somehow (a consequence of the tappet adjustment perhaps?) and was down to 1.1 on the CO. So I razzed it back up to 2.5 and it didn't seem to have a negative effect on the HCs either.
For the crack I held the revs at 3000rpm for about 30 seconds to see what happened to the HC reading then - came down to 160.
So all told then, it seems that the cams do increase the fuelling a bit at idle, but not to the extent that it won't pass an MOT, or indeed screw up your fuel consumption too badly. I noticed on the drive home that the car was happier pulling from 1500rpm too than it was previously, now nice and smooth down there as well as above 2000rpm.
Huzzah! After multiple attempts of pissing about, it is possible my engine is now actually set up and running correctly? Only Nick T and the dyno will find out in June! :D
Postby tourettes tony » Mon Nov 01, 2010 7:34 pm
hurrah :dmcdoors:
Postby arranj » Mon Nov 01, 2010 7:41 pm
jerzybondov wrote:Only Nick T and the dyno will find out in June! :D
You're waiting until June to dyno it? It'll probably be knackered (something else) by then! :lol:
Postby A Van » Mon Nov 01, 2010 8:40 pm
Gez, great news mate.
Glad you got it all sorted, must be a weight off your mind!
Postby RobvdVeer » Mon Nov 01, 2010 8:54 pm
jerzybondov wrote:Once the car was properly warm we went for it, revved it up to 2500rpm for 20 secs to purge it, then whack the pipe in and see what the HCs come back to in the next 15 secs or so. Answer: 637. It's a pass! Strangely the car had leaned itself off somehow (a consequence of the tappet adjustment perhaps?) and was down to 1.1 on the CO. So I razzed it back up to 2.5 and it didn't seem to have a negative effect on the HCs either.
Congratulations Gez! Looks like all the work has paid off!
Postby jerzybondov » Tue Nov 02, 2010 12:36 am
arranj wrote:You're waiting until June to dyno it? It'll probably be knackered (something else) by then! :lol:
Of course it will! I'll be arriving on a tow truck for the March meet :D
Re: #SUCCESS - GezTec - 25th September 2010
Postby jerzybondov » Tue May 17, 2011 6:12 pm
LOL. Just went back through this thread to find a link for the clutch I used - funnily enough the prediction about needing a tow truck the next time the car needed to go somewhere proved to be true! :D
Postby arranj » Tue May 17, 2011 6:17 pm
haha - I noticed the same thing with Julian's ball joints!
Clutch: viewtopic.php?f=26&t=24 (half way down the page)
Users browsing this forum: No registered users and 39 guests
