DPNW poly bushings for ARB - LCA
Re: DPNW poly bushings for ARB - LCA
Postby bozzzydmc » Fri Jul 03, 2009 10:57 am
19mm me old chip ... 55 ft lb when tightening up .... should be 2no nuts on each end, one locks the other down ...
Postby jerzybondov » Fri Jul 03, 2009 11:03 am
Nice one. Cheers Bozzy!
Postby Dan 6511 » Fri Jul 03, 2009 11:15 am
Your taking the arb off!!?? Decided to swap those blue bushes out for the DPNW ones then?
Postby DeLorean Cars » Fri Jul 03, 2009 11:48 am
Edit: pointless comment.
DeLorean Cars
VIN #: 4772, 3352
Postby jerzybondov » Fri Jul 03, 2009 11:52 am
Dan 6457 wrote:Your taking the arb off!!?? Decided to swap those blue bushes out for the DPNW ones then?
No I'm leaving the blue ones in - but my DPNW instructions tell me to loosen the whole ARB off to install just the front bushings. Makes it easier to do the fitting I guess...
Postby jerzybondov » Fri Jul 03, 2009 11:53 am
DeLorean Cars wrote:Edit: pointless comment.
It wasn't one about how I should definitely put Toby's in and take the others out was it? :D
Postby bozzzydmc » Fri Jul 03, 2009 1:44 pm
LOL ...dont know why that post tickled me ... :) :)
Its a bit like when you see a blank page at the end of a book and it says on it "This page is intentionally left blank" :)
Postby DeLorean Cars » Fri Jul 03, 2009 1:50 pm
I wrote "19mm" then realised I hadn't spotted the next page of discussion :mrgreen:
How about this then: A geninie sign in the middle of a field, in the middle of nowhere reading
"PLEASE DO NOT THROW STONES AT THIS SIGN"
I would HIGHLY recommend replacing the ones in the lower arm, otherwise you're not getting even half the advantage of Toby's kit. If you think about it, it's the ones in the arm that do most of the work - the original ones under the U-brackets can only deflect a few mm anyway.
DeLorean Cars
VIN #: 4772, 3352
Postby bozzzydmc » Fri Jul 03, 2009 1:55 pm
Oh and its fun trying to flex the 'split' bushings over the anti roll bar, tough little burgers them :)
Postby DeLorean Cars » Fri Jul 03, 2009 2:03 pm
Circlip pliers work a treat (the inny-to-outy flavour)
DeLorean Cars
VIN #: 4772, 3352
