Stainless Braided Brake Lines - £59.99
Stainless steel lettering and engine cover grilles, in stock and shipped from the UK
Re: Stainless Braided Brake Lines - £50 plus p+p
Postby arranj » Wed Dec 01, 2010 2:38 pm
Usually quick for these, but if you're in a real rush I would phone Julian: http://www.justbandits.com/contact.asp - he will answer his mobile straight away if he's not too busy making tea or staring at his calendars!
Postby bandit » Thu Dec 02, 2010 1:42 pm
Spoke to him yesterday, at home, as it happens, cos of this friggin' snow. We've had about 2 bloody foot of the stuff &it's still cumin like the clappers
Postby mnickels » Thu Dec 02, 2010 2:49 pm
bandit wrote:Spoke to him yesterday, at home, as it happens, cos of this friggin' snow. We've had about 2 bloody foot of the stuff &it's still cumin like the clappers
Not looking good for the weekend then!!!
Ireland Rep
mnickels
VIN #: 2456
Postby bandit » Thu Dec 02, 2010 8:29 pm
Should be OK Matt, if airports open, Lisa has bin' gettin' out in her 4 x 4, but I'm not goin to work at the un-Godly hour of 7am, so I stopped at home.
Postby bandit » Fri Dec 03, 2010 9:17 am
stevie67cars wrote:From ordering, how long will it take to get a set of these brake pipes out? Just want a set of the standard clear coated ones, but I am in a bit of a rush for them.
Stephen
#10213
Hi Stephen
Bagged up & will be leaving today, 1st class post
Julian
Postby bandit » Tue Jan 25, 2011 3:30 pm
Got a few sets of these in stock & ready to go if anyone needs them.
Postby RobvdVeer » Mon Apr 11, 2011 7:13 pm
Got some questions on the lines. I tried removing the old ones but one needs a bit more soak in WD to get unstuck. Almost broke the support bracket..
Anyway, here's a pic of the old and the new lines. I tried a fit but it seems that the 6-side bit is too short. The original are at least 9mm and the new ones are only 4mm thick. This way, the hose will spin in the socket. Almost impossible to tighten up because they keep spinning.
Postby RobvdVeer » Mon Apr 11, 2011 10:18 pm
Anybody else had that same thing happening?
Postby Peter Filsell » Sat Apr 16, 2011 10:06 am
Hi Rob,
I know Julian is out of the country till Monday, when he's back im sure he will be able to advise but Im sure Malc and Jules changed their brake lines the other weekend without any issues?
Peter Filsell
FIL675
Vin #1772
Peter Filsell
VIN #: 1772
Postby RobvdVeer » Sat Apr 16, 2011 12:09 pm
Peter Filsell wrote:Hi Rob,
Count yourselves lucky, took me all week to remove the old ones on the front only.
Anyhow I ground of the fixed nuts on the brackets so I can use 2 spanners to tighten them, and the new ones are all tightened up now. The rears will have to wait until autumn.
Return to Just Bandits
