I was telling you, we had to work on 11611.
This is Marco's car: it had a frame off in 2009 in order to fix the rust on the frame and so on.
First, we had a look at what happened to Andrea's 2.5 T
and at the new 3.0T
Time to work!
Job1: 11611 has huge alignment issues.
There are no more available threads in order to close the alignment, and so the tires are completely worn out in the inner side
We have to solve this trouble: every way is allowed..
Start time: 10H30 AM
Do you really think that it's easy to remove a steering wheel?
No, it isn't.
Job2 (description following) started at the same time
When nuts are blocked, we must unfreeze them!
Way 1: fire.. no way!
Way 2: saw, hammer and chisel.. no way!
Déjà-vu?
Way 3: angle grinder.. ok!
War trophy!
