Postby mnickels » Tue Apr 05, 2011 8:53 pm
bandit wrote:You got an extra day for the royal wedding farce as well
A nice Brucie bonus!
Ireland Rep
mnickels
VIN #: 2456
Postby tourettes tony » Tue Apr 05, 2011 10:08 pm
waste of time :evil: im working to get away from it
Postby mnickels » Thu Apr 07, 2011 5:05 pm
Where are all the dash panel indicators grounded. Nothing working there at the minute apart from the door buzzer?
Ireland Rep
mnickels
VIN #: 2456
Postby mnickels » Fri Apr 08, 2011 9:15 pm
What way are the accessory relays supposed to be wired? My instrument cluster isn't working. Think it is the supply to fuse 5 or else the grounding point. Any help?
Ireland Rep
mnickels
VIN #: 2456
Postby mnickels » Fri Apr 08, 2011 9:53 pm
mnickels wrote:What way are the accessory relays supposed to be wired? My instrument cluster isn't working. Think it is the supply to fuse 5 or else the grounding point. Any help?
Sorted
Ireland Rep
mnickels
VIN #: 2456
Postby A Van » Fri Apr 08, 2011 9:56 pm
Matt is it all ok? Missed the post
Postby mnickels » Fri Apr 08, 2011 10:00 pm
A Van wrote:Matt is it all ok? Missed the post
Can't get the dash to work. I think it is the grounding wherever it gets that but doubting the feed to it now fs. Thought the above diagram would help but looking closer maybe not.
Confused.com
Ireland Rep
mnickels
VIN #: 2456
Postby A Van » Fri Apr 08, 2011 10:02 pm
Any dash lights at all? Everything dead?
Postby mnickels » Fri Apr 08, 2011 10:07 pm
A Van wrote:Any dash lights at all? Everything dead?
The pain in the arse buzzer goes, the voltage and oil pressure seem to go backwards slightly. On cranking everything has at times lit up but majority of the time nothing.
Ireland Rep
mnickels
VIN #: 2456
Postby A Van » Fri Apr 08, 2011 10:09 pm
Sounds like shitty connection have you taken that connector of at the back and cleaned
