Postby RobvdVeer » Tue Apr 12, 2011 6:18 pm
tourettes tony wrote:chill rob, they have been on there for 30 years ;)
Took me 3 days to get the nuts off, and now the fucker is stuck in the hole.
Postby bozzzydmc » Tue Apr 12, 2011 6:20 pm
Yes ... Think yourself lucky that you still have a frame !
Postby RobvdVeer » Tue Apr 12, 2011 6:25 pm
In time, it'll be all right. Theres on thing I wouldn't know how to repair, that is the bracket attached to front the shock tower. I was thinking bubblegum perhaps?
Postby RobvdVeer » Tue Apr 12, 2011 6:33 pm
RobvdVeer wrote:In time, it'll be all right. Theres on thing I wouldn't know how to repair, that is the bracket attached to front the shock tower. I was thinking bubblegum perhaps?
I'll probably just bolt a new bracket to the shock tower.
Postby RobvdVeer » Fri Apr 15, 2011 6:36 pm
Front left & brake booster sneak preview:
Brake servo primed
Front left brake line test fitting
Postby bozzzydmc » Fri Apr 15, 2011 6:55 pm
Yummy ... Spax :)
Postby RobvdVeer » Fri Apr 15, 2011 7:08 pm
bozzzy wrote:Yummy ... Spax :)
It's almost a shame it aint the exact same yellow. :thumbsdown:
Postby RobvdVeer » Sat Apr 16, 2011 6:16 pm
Progress today:
- final coat of paint for servo and brackets
- drilled a hole in the frame to mount a new bracket for the brake line
- went out and bought nuts before going nuts
- installed front SS braided brake lines
- installed painted brake servo after paint has dried
- reinstalled clutch master (I had to loosen it to get the servo out). PS. Did I tell you those bolts in the footwell are a bitch to tighten?
- prepped the new master cylinder (new tank, etc.)
- bench-bled the new master cylinder
- installed the M/C in the car
- tightened some nuts and bolts
- torqued up the brake caliphers to the hubs (almost forgot!)
- loaded the brake fluid reservoir with brake fluid
- tightened up some more nuts and bolts
- sprayed rust protection on the area's that needed a touch-up after the work.
- And perhaps some other stuff I forgot about.
- found a bad connection in the back of the binnacle, causing my brake warning light to fail. Short story, it's fixed now.
Now I am completely tired, bad back, broken and I didn't even bleed the brakes. Alas, no American Sunday at Zandvoort tomorrow...
Postby RobvdVeer » Sat Apr 16, 2011 6:23 pm
Oh and of course some pictures of work in progress. My battery was empty, will be taking final pictures tomorrow (and Flash is not flattering)
Postby tourettes tony » Sat Apr 16, 2011 6:39 pm
looking alright there rob :D
