Postby RobvdVeer » Mon Apr 18, 2011 3:50 pm
I think I need a holiday :D :D :D :D
I even taped the screws to the marker. :oops:
box of spare parts
Postby Dan 6511 » Mon Apr 18, 2011 11:07 pm
Wooops!! But we all make mistakes like this... :oops:
Postby bozzzydmc » Tue Apr 19, 2011 7:55 am
Lol Rob .. So it was you that stole it ! :)
Can you remember why you took it off ?
Postby RobvdVeer » Tue Apr 19, 2011 9:37 am
bozzzy wrote:Lol Rob .. So it was you that stole it ! :)
Back in November or something, I was working on the door strut brackets. I had to loosen the rear quarter panels. First thing I did was remove the louvre and the right side marker. The quarter panel never came off as there was sufficient room to put the new bracket in. So the marker was off the car for at least 5 months.. :oops:
Postby bozzzydmc » Tue Apr 19, 2011 4:34 pm
Lol !
Well at least you haven't bought a new one eh :)
Postby RobvdVeer » Tue Apr 19, 2011 6:21 pm
bozzzy wrote:Lol !
I hope i didnt....
Postby RobvdVeer » Wed Apr 27, 2011 5:41 pm
Right lads, next issue.
First up, the A/C. Last saturday morning I drove up to my parents, confessed what I've done, and asked them to pardon their prodigal son. But the A/C was cycling nice and fine, good air coming out, only it was cycling a bit too fast to my knowledge. Instead of the 6 or 7 seconds at idle, it cycled every 1 or 2 at 3000 rpm cruising speed. Looks like my a/c is low on refridgerant, but I think this is quite unlikely having it fully serviced last autumn.
Next is something a bit worse, on the way up (same trip) the engine ran solid as a rock. I'd park it for about 2 hours and went back home (about 20 miles), but the engine seriously lacked power in the lower revs. Seemed to be misfiring at low revs. I had to disengage the clutch, rev up to 2500 somewhere to let the power kick in an then release the clutch to properly accelerate. I've had this problem before but i thought it fixed with the new vacuum hoses. Could this be an electrical problem perhaps?
Postby bozzzydmc » Wed Apr 27, 2011 6:16 pm
AC
Sounds like a low on gas issue to me, that or the AC circuit breaker is on its way out ...
Car Misfiring
Heck.. could be a number of things really but sounds like the problem is after a drive when the engine / fuel is still hot ?
Postby RobvdVeer » Wed Apr 27, 2011 6:49 pm
bozzzy wrote:Car Misfiring
Yes, usually happenes when the car is still hot.
Postby Admin-bloke » Wed Apr 27, 2011 7:00 pm
Does it not do this with a full fuel tank?
Just thinking it may be something with the pick up pipe in the tank.
Sometimes they get a small pin prick hole and it sucks air in.
Other times the pipe collapses and causes a constriction.
Shoving a coiled up stainless spring or coiled wire prevents this.
