An auto?
You mean to tell me that you've got that 500bhp engine from a race car, and you're attaching it to a 3-speed auto box?!?!
arranj wrote:An auto?
mnickels wrote:Doors- I am having a problem that I had with 2835 as well when I owned it. When the drivers door is closed the lock mechanism actuates with the impact slightly and the door cannot then be opened from the outside.Is there a science to this adjustment or is it trial and error?
Gearbox- I can't seem to get Neutral with everything now reconnected. Is there a chance the cable is now stretched or something damaged? It is an auto remember
mnickels wrote:I reconnected the gear mechanism to the selector as per the manual. Since it has been sitting on all 4 wheels though, no matter what position the selector is in I am unable to move the car or make contact that enables the start inhibit relay. I was able to do it before the frame off though. Also where does the other end of the vacuum pipe go to from beside the selector cable?
