Postby mnickels » Tue May 24, 2011 10:40 pm
Well it is game over I think. You are all welcome to visit my sick Delorean this weekend. Thanks to everyone who helped try to get her on the road for Eurofest.
Ireland Rep
mnickels
VIN #: 2456
Postby Admin-bloke » Wed May 25, 2011 9:03 am
mnickels wrote:Fluid OK. Idling and in the warm region. I don't understand, I have no gears at all but the gearbox is lifting the oil ok??? It is like it isn't connected to the engine at all. No matter what gear it is in there is nothing. It starts in Park and Neutral, doesn't start in others, reverse lights are on in reverse but no movement. All I did was drive to end of driveway and reverse back up and nothing since.
Try doing the fluid as I said earlier.
The oil may have just been pumped into the torque converter and dropped the level to the point where it can't pump oil.
Have you jacked the rear of the car up so the wheels are off the floow to see if the rear wheels move when first is applied and engine running?
Postby bozzzydmc » Wed May 25, 2011 10:35 am
'Final drive' is full of oil Matt ?
Postby mnickels » Wed May 25, 2011 11:24 am
Drained and refilled both last night as per the manual but made no odds
Ireland Rep
mnickels
VIN #: 2456
Postby conor » Wed Jun 08, 2011 2:39 pm
Hi Matt,
Did you get the gearbox sorted yet?
If you used gasket sealer on the cork gasket or the sump or both, your filter may be blocked by the excess sealent that is squeezed out. There may be enough to restrict the flow of fluid which would cause the box not to select the gears properly.
Drain the sump and either remove or clean the filter, refill with ATF and try again.
If you are going to clean the filter, take it apart by lifting the metal flap with a screw driver, clean out the mesh with petrol, then reassemble.
Conor
conor
VIN #: 10447 & 01866
Postby mnickels » Sat Jun 18, 2011 2:21 pm
OK had another bite at the car this morning. Took off the sump and removed the filter.
Once I got it split it looked like the attached picture. Once it was all refitted I was able to drive the car up and down the driveway. Success. There is a shuddering noise though which is possibly the brakes binding a bit. Haven't moved it more than a few feet but at least it moves!!!!!!!!!!!!!!!!!!!!!!
Now for a pint!
Not going to rush the car to Eurotec but I am sure you will all see it mobile soon.
If anyone knows where I can get the support bracket for my drivers side door trim (part 4 here http://www.delorean.com/store/c-317-8-7 ... -trim.aspx ) please let me know.
Ireland Rep
mnickels
VIN #: 2456
Postby A Van » Sat Jun 18, 2011 5:40 pm
Great news, you reckon that the filter was clogged all this time causing the problem?
Postby Admin-bloke » Sat Jun 18, 2011 5:54 pm
I am shocked to see how much crap is in there !
Good job it had a filter in it !
Postby delorean12uk » Sat Jun 18, 2011 6:32 pm
There are some that reckon you don't need gearbox filters
Postby Admin-bloke » Sat Jun 18, 2011 6:46 pm
Are they the ones with knackered gearboxes then?
