Y-Pipe switches wanted
Postby dmc4087 » Wed Sep 21, 2011 9:26 am
I need the two switches that are circled below
I probably need a y-pipe too if anybody has a spare?
Top
Lambda switch - 102478
Bottom
(Cant find this one on DMCH, know what it is?)
Re: Y-Pipe switches wanted
Postby Admin-bloke » Wed Sep 21, 2011 12:33 pm
The bottom one is the idle ecu thermistor.
There are 2 volvo types. Get the one which is 12k ohms at 20 degrees !
I can't remember the Bosch part number....
Postby dmc4087 » Wed Sep 21, 2011 2:03 pm
Postby bozzzydmc » Wed Sep 21, 2011 3:37 pm
Problem with that one is that it doesnt actually do what it is supposed to do :)
Postby dmc4087 » Wed Sep 21, 2011 4:07 pm
bozzzydmc wrote:Problem with that one is that it doesnt actually do what it is supposed to do :)
Is it needed then?
Postby Admin-bloke » Wed Sep 21, 2011 6:16 pm
Is it needed then?
Yes it is.
What Bozzzy is trying to say is that for the ecu to work correctly it needs another 10k ohm resistor wired in series with it.
Some gorgeus Admin-bloke found that out ;) xx
Postby tourettes tony » Wed Sep 21, 2011 6:35 pm
i think i have them il look later TT
Postby dmc4087 » Wed Sep 21, 2011 11:29 pm
Thanks AB - can you stop messing about and just come to Ireland and rewire my car? Refit the engine while your at it please :)
Tony, that would be superb. Thanks
Postby bozzzydmc » Thu Sep 22, 2011 9:37 am
.. And I still have a few little jumper wires that we made up that don't involve cutting the existing wiring if anyone would like one x
Postby Admin-bloke » Thu Sep 22, 2011 11:52 am
bozzzydmc wrote:.. And I still have a few little jumper wires that we made up that don't involve cutting the existing wiring if anyone would like one x
Bozzzys top plug and play inline resistor :thumbsup:
