Throttle cable
Throttle cable
Postby OllieWilks » Thu Feb 21, 2013 8:40 pm
Hi All, I need a new throttle cable, mines completely shot, has anyone got one they could sell me?
Looking to put the tub on next weekend so the sooner I can get one the better :)
Thanks very much
Ollie
http://www.deloreanhire.com
OllieWilks
VIN #: 3928, 3185
Re: Throttle cable
Postby Manxmann » Thu Feb 21, 2013 8:50 pm
When mine snapped I needed a solution quickly so I went down to the local parts shop an bought a remote fire extinguisher pull, removed the centre cord / chopped the handle off and threaded it down the D's old outer sheath.
http://www.ebay.co.uk/itm/OMP-12-Ft-Lon ... vi-content
That said I did buy a 'genuine' cable from Ed, which I still have somewhere if your desperate.
Remember to get a load of light oil down there first to fend off corrosion.
The Manx 'D' - VIN 17152
Manxmann
VIN #: 17152
Re: Throttle cable
Postby Dangermouse » Thu Feb 21, 2013 11:18 pm
I got mine at a B&Q home improvement type place where they see the bare wire by the ft/m. You will need to crimp something on the end that attaches to the pedal.
I put some antifreeze in the sheath also. Part of the de-ice recall procedure.
Re: Throttle cable
Postby bandit » Fri Feb 22, 2013 9:36 am
Anti-freeze! Won't be needing that, mine ain't going nowhere till' its at least 15 degrees.
